Old 3-Jun-2011, 8:57 AM   #1
canant
CHNM Vancouver ERP Error
I've noticed that under the list of "current" digital stations in the Vancouver, BC area, that CHNM-DT is has a max ERP of 0.83 kW. In fact, this station was long ago approved for and has been broadcasting with a max ERP of 8.3 kW. Can you correct this?
See also: http://www.crtc.gc.ca/eng/archive/2011/2011-231.htm Item #10 is an approved application for CHNM to continue broadcasting on channel 20 at max ERP of 8,300 kW post-transition.
canant is offline   Reply With Quote
Old 17-Jul-2011, 8:53 AM   #2
canant
Is this going to be fixed. Channel 20 with HAAT of 670 m and ERP of 8.3 kW is CHNM-DT's pre and post transitional allotment.
Old 17-Jul-2011, 6:49 PM   #3
Yes, it will be fixed. I'll take a look at what the latest IC database snapshot says.
Old 17-Jul-2011, 8:07 PM   #4
Thanks for the update! The data should be fixed now.
It turns out that the IC database still shows CHNM-DT as an active transmitter with 830 Watts. The 8.3 kW transmitter has a callsign of CHNM-DT(2) and is listed as "AU" (which by default goes into the "pending" category on TV Fool).
So to fix things, we removed the CHNM-DT records (830 Watts) and migrated the CHNM-DT(2) record (8.3 kW) into the "current" category.
I believe this now reflects what you were expecting.
