Old 3-Apr-2026, 12:09 AM   #1
billamy94
Antenna recommendation
Hi,
I will be moving later this year. I was hoping to get some advice on an antenna and the best direction to point it.
I currently have one of the old Denny Stacker antennas with an amplifier and a powered 8 way splitter. I am not opposed to getting something new or adding a second antenna.
The link to my report for the new address is here.
https://www.rabbitears.info/s/2600698
Any help would be appreciated.
Thanks,
Bill
billamy94 is offline   Reply With Quote
Old 2-May-2026, 1:40 PM   #2
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Different markets different directions.
Which markets are you after? Austin looks pretty good. Then you have a couple other markets. If you need to get the other two which are definitely doable you will need to have a different antennas, with a aTeleves SmartKom.
I would put a DATLR Mix 149884 an aim at Austin. I would get a second 149884 and aim at San Antonio for your largest selection of stations. You could let SmartKom pick your stations..
https://forum.tvfool.com/attachment....1&d=1777728569
https://forum.tvfool.com/attachment....1&d=1777729130
Old 11-May-2026, 4:31 AM   #3
billamy94
Thanks for your help. I’ll have to read about the SmartKom.
