Old 3-Dec-2018, 2:04 PM   #1
Fritz
antenna choices
http://www.tvfool.com/?option=com_wr...90389a48d693d0
only care about the 5 network stations.
The NBC affiliate, WESH, is the oddball at 68ยบ, but it is much closer.
Rather not put up anything longer than a 6' beam.
Not that anything other than a Yagi isn't acceptable.
No rotator.
Fritz is offline   Reply With Quote
Old 3-Dec-2018, 6:30 PM   #2
jrgagne99
All five networks are UHF and looks like will stay there after the repack. 90 degrees apart is tough. If they were 180 apart a Clearstream 2MAX would probably work great. It may work in this case too, you'll probably need to fiddle with the angle, maybe split the difference and aim N-NE. Maybe a 4-bay UHF such as the HDB4X would work too.
Another option is to try the HDB8X and aim one panel at 340 magnetic and the other at WESH (74 magnetic)
Old 4-Dec-2018, 8:19 PM   #3
Fritz
thanks very
Old 5-Dec-2018, 1:59 AM   #4
Nascarken
Banned
Yes do not forget about its 60with beem pattern
