Old 28-Nov-2018, 2:27 PM   #1
AlCorr
TV antenna & amp.
I need help on what tv antenna and amp. to buy. I live in New Bedford MA. 02740. I have a travel trailer in the yard that gets all the channels (2,4,5,6,10,11,12) Mass & RI. I put a small GE685 Yagi antenna and a Winegard LNA 200 preamplifier. Pointed the antenna 344* and all I get is channel 12. I turned the antenna all over and nothing. Do I need a bigger antenna or bigger amp.?
AlCorr is offline   Reply With Quote
Old 28-Nov-2018, 2:55 PM   #2
jrgagne99
First thing I would try is removing the amplifier and connect a short lead of coax directly to a TV. If your garden-variety RV antenna is picking up all those stations, the GE yagi should do at least as well-- if it is working properly. If you don't get anything after removing the pre-amp, I would suspect bad connections at the antenna balun or bad coax.
Old 28-Nov-2018, 3:49 PM   #3
AlCorr
http://www.tvfool.com/?option=com_wr...9038fc1cd090df
Old 29-Nov-2018, 1:08 PM   #4
rickbb
Based on that report you don't need an amp at all.
You are probably over driving the receiver and it thinks all it's seeing is noise and shutting off the channel.
Old 29-Nov-2018, 3:15 PM   #5
Nascarken
Banned
Hello I am frum mass the best one to use is a channel master 7777-amp
32:db
Old 29-Nov-2018, 3:45 PM   #6
The components that you have should work fine. I'd be looking for a wiring error with the power supply or a bad F connector.
Old 29-Nov-2018, 7:56 PM   #7
Nascarken
Banned
Hello Bedford mass if you need help I can stop buy and help you out if needed ??
Old 30-Nov-2018, 12:32 PM   #8
AlCorr
Yes, I need help, If only for someone to talk to and give some advise. Do you live in New Bedford?
Old 21-Dec-2018, 6:55 PM   #9
AlCorr
Is this a good for me? Channel Master CM-2020
Old 22-Dec-2018, 4:23 PM   #10
jrgagne99
Yes, or even the CM-2018 should get you most of the yellow stations in your TVF list.
Old 22-Dec-2018, 9:12 PM   #11
Nascarken
Banned
Yellow if spend money on tv antennas and mast mount AMP in mass
Go for the channel master 7777,and dont cut your recving skills short
Old 23-Dec-2018, 2:06 AM   #12
The CM7777 is the amp MOST likely to cause problems due to its excessive gain. We run into it every week, it seems. Too many folks that more gain is better then they call US to troubleshoot the antenna when the problem is actually the wrong amp is in use in moderate to strong signal areas.
Stick with a medium gain amp in the 15-20 dB range that has high resistance to internal overloading. You have signals that are sufficiently strong so that no amp is likely needed.
