Old 16-May-2011, 10:58 AM   #1
bilbothehobbit
Add request : CFTF-TV-10
Hi,
Can you add this station :
Channel : 26
Callsign : CFTF-TV-10
Affiliate : V
Common name : V télé
Old name : TQS
Language : French
TV type : Provincial Quebec local commercial TV Station from Rivière-du-Loup
Owner : Télé Inter-Rives
Location of the antenna : Baie St-Paul (Quebec, Canada)
Latitude : 47°25'37"
Longitude : -70°31'23"
Height of Antenna Above Terrain in meters : -10.3
Radiation Centre of Antenna Above Tower Base in meters : 35
Frequency in MHz : 542.00
Sources : http://www.user.dccnet.com/jonleblan...ations/QC.html
http://en.wikipedia.org/wiki/CFTF-TV
Thank you.
bilbothehobbit is offline   Reply With Quote
Old 16-May-2011, 7:09 PM   #2
Thanks for the update!
You should be able to see this transmitter in the latest database update under the "pending" transmitters. This should show up on any newly generated reports. If you have any problems finding it or see the need for any corrections, please let us know.
