Old 15-Jul-2017, 3:51 AM   #1
ccm2
Help with antenna MASS
Just turned off Cable and internet. Looking for a good setup to get most stations. Any help would be appreciated. Thank you in advance.
http://www.tvfool.com/?option=com_wr...e6a4fa0cbaaa41
ccm2 is offline   Reply With Quote
Old 15-Jul-2017, 1:26 PM   #2
JoeAZ
Greetings,
You are fortunate that you have so many strong signals from
different television markets. I would suggest the Antennas
Direct Clearstream 2Max. It will give you good bi-directional
reception either on your roof or in your attic. If you have lots
of trees nearby, try to position the antenna as far away as
possible. You'll need to experiment to see which location give
you the best reception of the most important stations to you.
If you choose to mount outdoors, be sure to properly ground
your system. It protects from lightning and can enhance your
reception as well. Use a good RG6 cable and keep it under
50 feet, if possible. Hope this gets you started. Keep it
simple, especially at first. Connect your antenna to ONE television
at first, add other televisions later, if you need to.
Old 18-Jul-2017, 3:42 AM   #3
ccm2
Thank you, I do have trees North and West
