Old 29-May-2017, 2:44 PM   #1
Bsean0714
Clearstream 2max in attic
Has anyone had luck with Clearstream 2max in the attic. The direction it needs to go will be facing the end of a gable and will have to penetrate osb and siding. I would rathere go this route. Also if using an amplifier, would I put the entire amplifier in the and tricks then split after the power source to amplifier?
Bsean0714 is offline   Reply With Quote
Old 29-May-2017, 3:45 PM   #2
Please try to keep all related conversations in a single thread, it helps keep things organized.
Old 29-May-2017, 6:38 PM   #3
Bsean0714
Sure thing. Thought I did. Sorry about that
