Old 27-May-2017, 4:07 PM   #1
fkgrable@aol.com
No Reception
http://www.tvfool.com/?option=com_wr...e6a4be54e88e7c
I was checking reception with an indoor antenna, and received all the channels except for one hi-vhf channel I need. ( I got 40 channels) I decided to put up RCA ANT751 to receive this one channel as well.
The antenna was installed at a level where the roof edge meets the side of the house. (Should I go higher?)
I pointed the antenna's short elements toward the towers. (All channels I need are between 83 degrees and 95 degrees with a range in miles of between 20.2 miles and 33.4 miles in an easterly direction.) All elements were unfolded per instructions.
I attached the transformer to tetrapole studs, and attached transformer to coaxial cable. I ran the cable thru attic and down interior wall to tv, attaching the coaxial cable to dtv hook up on back of tv. (Approximately 40' of cable)
I ran three or four scans in antenna mode, and got 0 channels.
My tv does have a digital tuner.
Any help is appreciated.
fkgrable@aol.com is offline   Reply With Quote
Old 27-May-2017, 5:05 PM   #2
JoeAZ
None of your location information pulls up. From the very
limited information you have given us so far, it would seem
to be a bad transformer or a bad cable.
Old 27-May-2017, 5:49 PM   #3
fkgrable@aol.com
I damaged transformer that came with antenna, so I bought new matching transformer.
New rg6 cable was used.
This is my zip 36609. I tried to add link - apparently it did not work.
Old 27-May-2017, 6:11 PM   #4
Consider these possibilities.
The replacement balun is also bad.
The coax was kinked and is now shorted.
The center conductor of the coax is bent over in the connector.
The center connector of the coax is too short to make contact.
Old 27-May-2017, 6:24 PM   #5
JoeAZ
You are just West of Mobile, Alabama according to your zip,
33609. You have some very strong signals in your area.
It just keeps going back to the transformer/balun or cable
or both is/are bad..... Do you have the cable properly attached
to the correct point on your television???
Old 27-May-2017, 7:32 PM   #6
fkgrable@aol.com
Yes, the cable is connected to the DTV/TV connector on back of the TV.
I do have strong signals to the towers as demonstrated by receiving 40 channels with the indoor Mohu 50 Leaf antenna.
Raising the height of the antenna 6 feet probably would not help, since I am getting no reception, right?
All I know to do is buy another transformer and more cable and give that a try.
I am using two pieces of cable using a connector to put them together. Maybe a single 50' piece would do the trick?
Old 27-May-2017, 11:40 PM   #7
JoeAZ
Here is what I would do.
I would remove the new antenna from the roof.
Connect the RCA antenna to 50 feet of NEW RG6 cable
and see what you get. If it works, the other cable
is bad or the connectors/connections are bad. If it
doesn't work, replace the balun/transformer. It that
works you know what the problem was. If it still
doesn't work I'd try another television. Are you
set for OTA/antenna??? Are you on the correct input?
Regards,
Joe
Old 28-May-2017, 3:22 AM   #8
fkgrable@aol.com
What do you mean "remove the new antenna from the roof"? The antenna is actually on the side of the house at the level where the roof slopes down to the side of the house.
The TV is fine. I have already used DTV/TV input to scan for channels with an indoor antenna, receiving 40 channels, but not receiving the one hi-vhf channel I want.
Old 28-May-2017, 1:53 PM   #9
JoeAZ
Ooops, remove the antenna from the side of the house, connect to 50 ft
of NEW RG6, connect to your TV, point in an Easterly direction and
do a scan....
"I am using two pieces of cable using a connector to put them together. Maybe a single 50' piece would do the trick?" That is cause for concern... Either the connector or connections on your cables could be damaged or defective...... Hope this helps you.
Old 28-May-2017, 2:01 PM   #10
fkgrable@aol.com
I am still not clear on removing the antenna from the roof or side of the house. If I remove the antenna, where do I place it?
Old 28-May-2017, 2:48 PM   #11
Right
No, don't remove the RCA ANT751; leave it where it is.
The TV and the Mohu seem to be OK because they give you reception, but the RCA outside doesn't work.
So, you have to make some substitutions to find out if the antenna, coax or antenna location are bad.
The Mohu Leaf 50 comes with an amplifier. Are you using the amplifier?
I suggest you try the Mohu antenna outside (no amp) using the coax that goes to the RCA antenna, to see if the coax is OK.
Old 28-May-2017, 3:01 PM   #12
fkgrable@aol.com
With the MOHU leaf I received 40 channels without the amp, and 0 channels with the amp.
I will try to retrieve the antenna cable and to see if there is reception with the Mohu.
Old 28-May-2017, 6:06 PM   #13
JoeAZ
The RCA antenna is fairly small. I was suggesting that you remove the
antenna and use it in place of the MOHU antenna either inside or
on a porch, balcony, etc with new RG6 cable. You can place the antenna,
temporarily, anywhere you wish or have someone hold it....
Old 28-May-2017, 6:10 PM   #14
JoeAZ
I have been under the impression that if you try to use an amplified
antenna without powering the amplifier, it would not allow any signal
to pass through. Sort of like how a guitar amp operates. That is why
I suggested removing the outside antenna to test both the antenna
AND cable as well.
Old 28-May-2017, 7:04 PM   #15
fkgrable@aol.com
I did power the amp, but with no luck, better without it.
Old 29-May-2017, 1:34 PM   #16
fkgrable@aol.com
I am happy to report that I have reception. I pulled a new 50' length of cable, ran a scan, and got 41 channels, including the hi-vhf channel I could not get with indoor antenna.
The reception is clearer than Comcast. So, good-bye Comcast.
