Old 14-Apr-2017, 5:09 PM   #1
DenMike99
How to connect HDB8X to 2 maybe 3 TV's
The two cables from the HDB8X antenna goes into a combiner with one output. From there I need to feed one tv in one side of the house and 1 (maybe more later) in the other side of the house.
How is it best to do that?
I was thinking about adding a splitter after the antennas combiner, but that sounds kind of weird. First combining 2 and then splitting in 2. Is that the way to go?
DenMike99 is offline   Reply With Quote
Old 14-Apr-2017, 5:28 PM   #2
Yes, that is the correct generally procedure.
Old 14-Apr-2017, 6:49 PM   #3
DenMike99
One more question then..
What is the difference between these type of splitters:
https://www.amazon.com/uxcell-Female...dp/B00AFX393W/
and this kind
https://www.amazon.com/CHANNEL-2532-.../dp/B00006JPE1
Old 14-Apr-2017, 7:39 PM   #4
The first is a simple tee- it's just plain, straight wire between the three ports.
The second is a proper transformer-type splitter that keeps the impedance of all three ports matched. The tee does not.
