Old 4-Nov-2016, 9:34 AM   #1
TheWombat
Reception/Antenna help Cary, NC
Hi,
Looking for some help/validation of a potential roof mounted antenna to replace my existing attic antenna. I live in Cary, NC and from reviewing the TVFool signal analysis report it looks like the majority of the TV stations are in an ESE direction with a few others in WNW.
One of our neighbors has a Winegard Flatwave FL6550A and is happy with it. I was therefore going to also buy the Flatwave or a Marathon HDTV antenna. Before I buy one I thought I'd reach out to the forum for feedback/recommendations. I would rather not have multiple directional antennas etc if possible from an aesthetics perspective.
The antenna would be mounted on an East facing (99 deg magnetic) roof and would be around 25 to 30' above ground level. There is a treeline about 40 foot away from the house that would be between the anteena and the tower. The trees are higher than the house.
Signal Analysis Report:
http://www.tvfool.com/?option=com_wr...dfaf989fc62f2f
I currently have an AmazonBasics Ultra-Thin Amplified Indoor HDTV Antenna - 50 Mile Range (https://www.amazon.com/gp/product/B00DIFIP06) in the attic. I have a passive 2-way splitter, although I plan to replace this with a 3 or 4-way splitter so I can feed 3-4 TVs.
Below I have listed whether I currently am able to receive the channel using my Amazon Basics antenna in the attic. The order of the stations matches the TVFool report:
WUNC 25 (4.1) PBS - Receive
WRDC 28 (28.1) MyN - Receive
WLFL 27 (22.1) CW - Usually Receive
WRAL 48 (5.1) CBS - Receive
WRAZ 49 (50.1) Fox - Receive
WUVC 38 (40.1) Uni - Receive
WNCN 17 (17.1) NBC - Sometimes Receive
WTVD 11 (11.1) ABC - Usually Receive
W24CP 24 - Receive
WCWG 19 (20.1) CW - Sometimes Receive
WIRP 22 - Receive
WFMY 51 (2.1) CBS - Sometimes Receive
WTNC 40 - Sometimes Receive
WXLV 29 (45.1) ABC - Do not receive
WMYV 33 (48.1) MyN - Do not receive
WUBX 31 - Do not receive
Where I state 'Sometimes Receive' or 'Usually Receive' it means that depending on how I position the current antenna and/or the time of day/weather I have been able to receive the channel.
I would like to have a solution that consistently receives:
ABC
CBS
CW
Fox
MyN
NBC
PBS
thanks
Alex
TheWombat is offline   Reply With Quote
Old 4-Nov-2016, 6:56 PM   #2
Hello, Alex:
All the networks you want are available from the ESE.
The trees in the signal path are a wild card. Try a Winegard HD7694P antenna without a preamp, with just one TV. Then, add the splitter. If the signals become too weak, replace the passive splitter with a CM3414 distribution amp.
If you have a problem with WTVD ABC on real channel 11, you might have FM interference.
http://www.fmfool.com/modeling/tmp/e...d/Radar-FM.png
Old 5-Nov-2016, 2:53 AM   #3
TheWombat
Thank you!
