Old 11-Jul-2016, 4:13 AM   #1
Danske
How close can I install a VHF and UHF antenna?
I have the two antennas linked below. VHF antenna is installed in attic and works great. The UHF antenna I will either need to place about a foot behind the VHF antenna or about 50 feet apart. Will I be ok mounting these two a foot apart?
http://www.mcmelectronics.com/produc...-2476-/30-2476
https://www.amazon.com/Antenna-Direc...s=Db8e+antenna
Danske is offline   Reply With Quote
Old 11-Jul-2016, 5:13 AM   #2
Ideally, avoid putting one antenna in the path of another. However, feel free to experiment.
As a rule of thumb mounting one above the other or side by side with at least 3' of separation will limit interaction between the two antennas, Greater separation is generally better.
