Old 5-Jun-2016, 3:10 AM   #1
TommyT
Smile Looking for advise on antenna
I live in Harrison, AR, which is located in North Arkansas in the Ozark Mountains. I am approximately 60 miles south of Springfield, Mo, which has several OTA stations. The terrain is hilly and my nyou eighborhood has a lot of trees. I am interested in cutting my cable, but worry about reception at my site. My TV Analysis is the following:
http://www.tvfool.com/?option=com_wr...e2cb0056757a63
Do you think I can get reception in my area, and if so what antennas would give me the best results?
Any advise will be greatly appreciated.
TommyT is offline   Reply With Quote
Old 5-Jun-2016, 7:26 PM   #2
Welcome, TommyT:
I am worried too, Tommy. The Springfield signals are weak and the terrain and trees can be a problem.
I think your chances are pretty good if you can get the antenna high enough to clear the trees. You will need to try it to find out.
I suggest a Winegard HD7698P antenna aimed at 8 degrees magnetic and a Channel Master 7778 or Antennas Direct Juice preamp.
Old 5-Jun-2016, 8:35 PM   #3
You can see that you are on the fringe of coverage for KSPR ABC:
Here is another coverage map. Red color is weak signal. No red, weaker signal, like Windsor Dr:
Old 5-Jun-2016, 9:02 PM   #4
TommyT
Thanks for the reply. The trees here very tall. No chance of getting an antenna up higher than they are. Some one needs to invent a device, like a meter, that would allow you to check your potential signals and signal strength from your home, before you purchase an antenna.
Old 5-Jun-2016, 9:18 PM   #5
That would be a good idea. The tvfool report is a computer simulation that predicts signal strengths accurate to about a football field length for location. The report does not take into consideration trees or other buildings in the signal path.
The best you can do would be to set up a smaller temporary antenna and use a TV or converter box that has a signal strength meter. If it looks promising, you could go for the big antenna. You could buy a signal level meter, but it would be cheaper to have an antenna installer make some measurements for you to tell you what your chances are. You happen to be in one of the better signal areas in Harrison.
A generic report for Harrison shows KSPR a lot weaker, -6.3 dB NM instead of +14.6 dB NM, a difference of 20.9 dB.
Generic report for Harrison, intersection of Stephenson Ave and Main St, 36.229794, -93.107677
The elevation there is 1050 feet, 200 feet lower than your location @ 1250 feet.
http://www.tvfool.com/?option=com_wr...e2cbec83046e47
Some people even run a tvfool report before they purchase a home.
