Old 26-Jan-2016, 2:58 AM   #1
dodgeram2500
Antenna Recommendation
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d51344010e4a4d6
Hello all, I just purchased a house in the country and I'm not interested in purchasing tv every month! My general plan is to build my setup one antenna at a time, and avoid splitters/ganging etc. Every time I add an antenna I'll add a tuner. Only one TV for now. Note that I used 25' for height on the report, but I may be able to go higher.
Step one: I'd like to get the Ottawa channels. On my TVFool report, these are the channels at 288/272 degrees true. Do you think that a HD8200U pointed between the two towers (at, say 280*) would be able to pick them all up, or would it be better to have a db8e with one bank pointed at each tower and vhf add-on.
I don't mind using a pre-amp, but am a little concerned with the ultra close channel 8 analog/fm radio tower.
Step two: 91xg pointed at 119 true for the US channels. I'm not worried about getting ABC on 13...I've heard its impossible, lol. Pre-amp will be used here as well.
Step three: (or should this be step one?) DB8e or similar with one bank pointed at Montreal (64* true), and the other bank pointed at roughly 200* true.
Thanks for any thoughts and replies! I'm jealous of all of you who can get 20+ channels on one antenna!
dodgeram2500 is offline   Reply With Quote
Old 26-Jan-2016, 11:10 AM   #2
Here is the repaired TVFool link: http://www.tvfool.com/?option=com_wr...51344010e4a4d6
FMFool does not provide clickable links, you must save it as an image, then post that image.
The HD8200 is not a suitable choice as there are no low VHF stations anywhere in your area. You can use one, but there's a lot of unused metal there.
You will probably need to attenuate both the immediate analog channel 8 as well as FM by 25+ dB to keep them out of the system. www.tinlee.com over in Toronto can custom make one for you. All you'd need is a low-pass filter that takes out everything channel 8 and below.
1. For Ottawa, select either a large high VHF/UHF combo or a separate UHF and a separate high-VHF antenna. You will need a suitable preamplifier.
2. Your idea is on track.
3. Unlikely to work. Repeat step one advice instead.
Old 26-Jan-2016, 11:49 AM   #3
I agree with ADTech; you aren't going to get what you want without a custom filter to attenuate real channel 8 and FM signals. But, IIRC, the filter should be a high pass filter, not a low pass filter designed to attenuate frequencies below real channel 10 and pass frequencies above real channel 8.
That is correct, FM reports don't link like TV reports. But it is possible to create a link of an FM report, which is what I have done based on the short coordinates of your TV report:
http://www.fmfool.com/modeling/tmp/7...0/Radar-FM.png
CHOD-FM at -5.9 dBm is strong enough to give you a problem. I understand that FM FOOL might not be up to date on Canadian FM signals. You can do your own report here to see how close I came:
Old 26-Jan-2016, 6:21 PM   #4
Doh! Reminder: Have another cup of coffee and wake up first...
:sheepish grin:
Old 27-Jan-2016, 12:07 AM   #5
dodgeram2500
Excellent, thanks for the info guys. I will make sure I use a pre-amp and a custom high pass attenuator. For experimentation purposes, is it okay to hook up to the tv without the attenuator/pre-amp, or will it probably blow the tuner?
Also, I know many people don't recommend the 7777 pre amp, but am I right to assume that in my situation with most of the channels being pretty weak this would be a good choice?
Old 27-Jan-2016, 1:20 AM   #6
Please don't call it an attenuator; that is a different device. It will attenuate channel 8 making it weaker, but you must call it a high pass filter when you talk to a Tin Lee Electronics filter engineer and send him your tvfool report by email.
http://www.tinlee.com/contactUs.php
The filter will probably cost more than $100, so you want to get it right. We don't see any other alternative to the custom filter, unless you are willing to settle for fewer channels.
It is important to ground the coax with a grounding block to reject your strong local interference, otherwise it will get directly into the TV cabinet.
cornwall, fringe, lancaster, weak signal
