Old 25-Jan-2016, 2:55 PM   #1
HoosierDaddy
NW Indiana/ Chicagoland antenna findings.
I am just south of Valparaiso, In.
I'm mainly posting this for others in the area to have a reference of some sort if they are looking to cut the cable like I just did.
Saving $80 a month now. It will basically pay for itself in a month.
Of course, I welcome any further discussion.
I bought a Clearstream 2V from BestBuy , figuring I could return if it didn't work.
I see no need for that now. The antenna, only 10' above ground , in the house(temporarily), ROCKS!
I think I get all the Chicago stations listed , the main ones, ABC, NBC, CBS, WGN, etc are at 92% or better on the TV's signal meter.
Hopefully, eave or attic mounting the antenna right at the peak(35' approx.) will work just as well as it currently does mounted to the fireplace mantel right next to the TV (temporarily, 10'AGL).
Approx. 10' AGL
http://www.tvfool.com/?option=com_wr...51342ba7691f29
Approx 35' AGL
http://www.tvfool.com/?option=com_wr...513484d8b39927
I posted the 10" AGL for one reason, that being, in reality , the antenna at 10' is picking up channels more like the 35' plot.
Surprisingly, it is starting to pick up the Southbend channels WSBT and WNDU. They are pixelated and basically unwatchable, but I am really curious what will happen when the antenna is way up on the roof peak of the second story.
Since the weather is lousy I am going to attempt an attic mount for now and see how that works.
Doing so will add probably at least 50 foot of RG6 to the run , since the attic lead runs to the basement to the service equipment area and then branches out to the TV locations.
We only use 1 TV, so there will just be a simple coax coupler in the basement.
Does anybody foresee any issues with a coax run of 50 to 70 foot?
HoosierDaddy is offline   Reply With Quote
Old 25-Jan-2016, 3:35 PM   #2
Your tvfool report assumes an antenna with 0 dB gain outside and in the clear. It doesn't take into consideration building loss for an indoor or attic location, or loss from trees or other buildings in the signal path. The gain of your antenna can be added to the NM figure on your report to make it more positive.
As long as there sufficient signal strength for the tuner to lock on to the signal, you will not see a difference on the screen.
Let the signal strength meter on your TV be your guide. You will soon find out how weak a signal can be and still be received.
For an attic antenna, you can always add a preamp near the antenna or a distribution amp further downstream.
Old 27-Jan-2016, 10:17 PM   #3
HoosierDaddy
Thanks Rabbit73.
I'll continue to iron the bugs out as I encounter them. This forum seems to be an incredible resource thus far.
My only remaining concern is getting FM to my stereo receiver. The typical vinyl FM cable antenna has proven worthless and unsightly.
I need to go over to FM fool and do my homework. Maybe start a thread there if needed.
Might be as simple as buying a decent radio antenna ...
Old 28-Jan-2016, 12:22 AM   #4
There is "here".
Order one of these and use it to tap off FM from the C2V's signal first. Even though the VHF element is a bit short for best FM performance, it does remarkably well.
http://www.solidsignal.com/pview.asp...HLSJ%29&q=hlsj
You can use a standard splitter for testing if you happen to have one, but the HLSJ is a more effective choice.
Old 1-Feb-2016, 2:29 PM   #5
HoosierDaddy
There is "here".
That is excellent! Thanks!
