Old 25-Nov-2015, 7:12 PM   #1
icunmypc
Smile Newbie Antenna setup
I am new to the OTA world and this forum. I am trying to figure out what the best antenna would be for my location. I plan to mount to the eve of the house with a 3 foot mast that I already mounted. (I purchased a Lava HD-8008 omnipro multi directional) I setup the Lava antenna and tested the reception, but I wasn't very happy with the constant signal freeze. I read information in the forums that didn't rate the Lava antennas very well, so I have removed it and returned it. I am hoping to get the as many channels as available. I have a Tivo series 3 that I plan to use to receive the channels and then connect to my HD TV. Here is my signal tvfool report... http://www.tvfool.com/?option=com_wr...b97d26ae533b15
Thanks for any help.
icunmypc is offline   Reply With Quote
Old 28-Nov-2015, 5:33 PM   #2
Welcome, icunmypc:
The preamp of the Lava was probably overloaded by your strongest signals.
I suggest you try the Antennas Direct C2V antenna, no preamp.
The loops will pick up UHF channels, real channels 14-51. Aim north.
The dipole will pick up VHF-High channels 13, 11, and 9.
Use the TiVo diagnostics screen to monitor signal strength, SNR, and uncorrected errors to help you adjust the antenna.
You have some strong local FM signals that might interfere with TV reception.
http://www.fmfool.com/modeling/tmp/d...5/Radar-FM.png
If so, insert an FM filter in the coax.
Old 29-Nov-2015, 7:47 AM   #3
icunmypc
Thank you for the information Rabbit73. I will purchase the new antenna and grounding equipment and once I get it set up I will post how things are looking.
