Old 26-Oct-2015, 12:27 AM   #1
jds_innc
Antenna Suggestions
Trying to help out parents. Here is the link to the report
http://www.tvfool.com/?option=com_wr...8e03b0bc2e3962
Looking at possibly replacing current satellite setup. Mainly looking at options for CBS (Real 40), NBC (31), ABC (13) , and FOX (29).
jds_innc is offline   Reply With Quote
Old 26-Oct-2015, 1:42 PM   #2
Jake V
Welcome, jds_innc!
You did not enter a value for the antenna height when you created your TV Fool Report. Can you please prepare a new report with the intended height of the antenna?
Also, where are you hoping to put the antenna? Outside on the roof? In the attic (attics can be challenging)?
From your current report, you have both high VHF and UHF signals, so one of the larger combination antennas pointed at 25 degrees on a compass is likely the solution. But a more accurate TV Fool Report is needed first.
Jake
Old 26-Oct-2015, 1:47 PM   #3
jds_innc
Thanks.
Here is an updated report. I'm not exactly certain of the height, but this will be an outdoor mount. Most likely be outside on the roof, so I'm guesstimating here.
http://www.tvfool.com/?option=com_wr...8e03cde0bc825e
Thanks again!
Old 26-Oct-2015, 4:57 PM   #4
I'd go with an HD7694P with a modest gain preamp such as the TVPRAMP-1R.
