Old 23-Apr-2011, 6:50 PM   #1
Heywood43
What type of antenna is this?
I moved into a house that already had this antenna on the roof. I don't see any inside connections and was thinking of using it for TV or even FM for my basement receiver. Before I make the trip onto the roof I figure I find out exactly what I have.
I am guessing it is a TV antenna but when I researched online I can't seem to find one that looks like it. Can anyone tell what type of antenna this is?
Thank you
Heywood43 is offline   Reply With Quote
Old 23-Apr-2011, 7:41 PM   #2
That looks like a couple of very old (probably worn out) VHF TV antennas. In it's prime the larger would have done well as an FM antenna.
I don't want to be critical of the photo, but I can't see the entire antenna, it's possible that it is a single 2-bay VHF... Electrically similar to the UHF panel antenna designs.
The twin lead wire probably rotted away in the sun years ago. Which is why you can't find any connection inside the house.
As I drive or walk around the neighborhoods here in the Seattle Metro area, I still see a few of that type antenna. Virtually all have been abandon since the 60's and 70's.
Old 24-Apr-2011, 1:38 AM   #3
Heywood43
Thanks for the response. I figured it was something pretty old. And no worries on the photo criticism. It was taken with a my cell phone while on a ladder. As I said before I haven't ventured onto the roof yet, this was my best attempt while cleaning the gutter
I have cable for TV so that's not a big deal but I would like something for AM/FM reception. I might be better served to buy something new so know I have an antenna that works.
Old 24-Apr-2011, 2:11 AM   #4
Antennacraft have a couple choices in FM antennas. http://www.antennacraft.net/Antennas/AntennasFM.html
Winegard is also a reliable option. http://www.winegard.com/offair/radio.php
Antennas Direct V4 is yet another option. http://www.antennasdirect.com/store/V4_antenna.html
Old 24-Apr-2011, 8:35 PM   #5
Tv antenna design
Those 2 antennas are 2 Very Old VHF antenna designs. They are not UHF antennas. . If you will like more help with the Correct antenna for your location then do this , http://forum.tvfool.com/showthread.php?t=4 in the help with reception part of tvfool. It is Ok to do what the other question askers do and post a tvfool radar report.
Old 1-Aug-2011, 1:45 AM   #6
Jim5506
I believe they called those conical antennas, sort of like having multiple rabbit ears, or a larger version of today's UHF bow tie type antenna but for VHF.
Jim5506 is offline   Reply With Quote
