Old 28-Aug-2015, 7:17 PM   #1
ativa
Report and antenna options?
Hello everyone,
Thank you for taking the time to read this:
I currently have satellite t.v and I REALLY am tired of paying for 3-4 channels that I watch, so I started browsing around and found this site. I have ran the report for my exact address and from what I can tell, it seems I should have a fairly easy time getting reception. I wanted to see if someone here could browse over it and confirm it.
http://www.tvfool.com/?option=com_wr...8e03e047ce7401
Then comes the mounting issue. Since I currently have Satellite and the Coax runs throughout the house to two locations could I utilize the existing COAX cables and mount the antenna near where the dish was?
Based off the report, what would be a good antenna to grab also?
Thanks again, I'm %100 green to this.
ativa is offline   Reply With Quote
Old 28-Aug-2015, 7:53 PM   #2
Just about any small UHF/high VHF combo antenna should work. Our ClearStream 2V would be my recommendation. No amp is needed unless you're going to supply the whole neighborhood with signal.
Existing coax, as long as it is not longer used for anything else, works great. That means that your cable-provided internet or VOIP service must be completely segregated from your antenna signals. NO EXCEPTIONS.
