Old 28-Jul-2015, 4:21 PM   #1
gorny
IS this setup gunna Help
http://www.tvfool.com/?option=com_wr...8e03991b2f020a
Channel Master TV Antenna Rotator System w/ IR Remote(CM9521A)
AntennaCraft HD1200 Heavy Duty TV Antenna VHF / UHF / FM Outdoor 51 Element Off-Air Local High Definition Digital Signal HDTV Television Aerial, RED ZONE, Part # HD-1200 | With 50' FT Coax Cable
Channel Master Channel Master High Gain Antenna Preamplifier - CM7777
Iwas thinking of using these products in hopes to improve my reception.
Not sure if my area is like a limbo region.
ANY help much appreciated.
Gorny
gorny is offline   Reply With Quote
Old 28-Jul-2015, 6:05 PM   #2
Absolutely not. The CM7777 will overload from the strong signals. You have four transmitters within 5 miles of you, assuming all of WGAL's are on the air.
No amp. Try it that way.
You'll also likely find the rotor won't last long with that big of an antenna on it.
Old 28-Jul-2015, 6:19 PM   #3
gorny
so get rid of rotor get rid of amp
how bout just the gigantic antenna do I try that. right now I have a very old and very modified large arrow antenna. I am also using ribbon wire. I was thinking of upgrading to a shielded cable.
will that help me get cbs 21.1 or pbs in Harrisburg.
or should I be content with abc nbc fox and Baltimore channels.
I really appreciate your help.
Old 28-Jul-2015, 6:30 PM   #4
You'll need to identify stations by their call letters which are unambiguous.
Old 28-Jul-2015, 6:49 PM   #5
gorny
I get
8.1 8.2 wgal great
15.1 wlyh 15.2 these go in an out with rain
21.1 whptv 21.2 these did come in until I rotated antenna slighty by hand
27.1 whtm 27.2 27.3 come in only when I don't get 21.1
43.1 wpmt 43.2 43.3 really good
49.1 wgcb 49.2 49.3 really good
my hope and goal is to try and get 21.1 and 21.2 and 33.1 witf
but I never have gotten witf with full 360 degree rotation of antenna
thanx ad
