Old 13-Jul-2015, 2:52 PM   #1
rgf
Setting Up New Antenna
I have been using a Mohu Leaf 50 in the house and it does well; In fact it does better than the ANT751 that I purchased to replace it and have in the attic. My question, is there a way to maybe increase the reception with the ANT751 in the attic or should I just stay with the Leaf 50?
Would a preamp help? I may move it outside and I know this will help, but wonder how much.
Any help or suggestions would be appreciated.
Here is my signal map: http://www.tvfool.com/?option=com_wr...8e0301a2346754
rgf is offline   Reply With Quote
Old 13-Jul-2015, 5:29 PM   #2
rickbb
Outside as high as you can get it will "almost always" be better than in an attic. Roofing material and insulation can bounce/block signals in strange ways. Makes it very hard if not impossible to predict what you will get.
Old 13-Jul-2015, 5:55 PM   #3
rgf
Thanks for the reply...
That is understood, but the HOA has rules. I may be able to set it outside where no one will really notice it, but would like to try to make it work in the attic first.
Old 13-Jul-2015, 6:32 PM   #4
The FCC also has rules that say that you CAN, in many cases, have an antenna outside not matter what the HOA says:
https://www.fcc.gov/guides/over-air-...n-devices-rule
