Old 3-Jul-2015, 2:25 PM   #1
LoSx
Rural VA Need Help
I was wondering what you thought for getting channels at this location. I can get the antenna about 25' AGL as we are right at the water..
Here is the tv fool report at 25'
http://www.tvfool.com/?option=com_wr...8e033624cc6d2a
50'
http://www.tvfool.com/?option=com_wr...8e03337dd15538
100'
http://www.tvfool.com/?option=com_wr...8e030b82f8bc41
FMFool report if needed, I probably need an FM filter
Going up does nothing for me it seems which is ok since it would be hard to get very high. Any suggestions for trying to pick up the DC stations? Particularly 4,5,7,9,20,50 if possible
LoSx is offline   Reply With Quote
Old 3-Jul-2015, 5:24 PM   #2
Flint Ridge
Junior Member Wannabe
I just learned the other day that FM fool URL does not work like the TVFool one. You will need to post an image of it.
Old 4-Jul-2015, 1:03 PM   #3
Jake V
Your TV Fool Report is only resolved to the block level. Try re-doing it with these instructions: http://forum.tvfool.com/showthread.php?t=14508 - It might or might not make a difference but is worth dong.
Old 8-Jul-2015, 2:06 AM   #4
LoSx
Sorry just got back in town. Was actually down there and of course it has no internet and barely cell phone coverage. It didn't change much but here is an updated tv fool report.
http://www.tvfool.com/?option=com_wr...8e03ef731f1152
Here is FM Fool:
I figure I definitely need a preamp and am torn between the CM 7777 and CM7778 and also which antenna to get to grab the most channels. I figure those pre amp's have FM blockers so I won't need that.
Old 18-Jul-2015, 8:01 PM   #5
LoSx
Anyone have any antenna recommendations?
Old 19-Jul-2015, 2:21 AM   #6
Winegard HD7698P aimed at 351 degrees magnetic and CM7777.
I see a lot of trees in your area. I hope there are no trees in the signal path, they really mess with TV signals.
Your TVFOOL report doesn't take them into consideration.
