Old 19-Jun-2015, 4:54 PM   #1
slcole
Antenna suggestions for Eastern Tennessee
http://www.tvfool.com/?option=com_wr...8230367ae17952
I'm in eastern tn about 50 miles from Knoxville. I would like suggestion on equipment I need to get our Knoxville network stations. Currently I have directv and want to cut the cord. I can install an outside antenna and have no close by restrictions.
I would like to get the following channels. The first three are the Knoxville stations but it would be a bonus if I could get the last three also from Tri Cities.
WBIR, 257 degrees
WVLT, 257 degrees
WATE, 257 degrees
WETP, 8 degrees
WCYB, 81 degrees
WJHL, 81 degrees
Thanks in advance for suggestions.
slcole is offline   Reply With Quote
Old 19-Jun-2015, 5:32 PM   #2
Jake V
81 degrees and 257 degrees are almost in totally opposite directions. For the UHF stations I would consider an Antennas Direct DB-8e with the reflector removed to get the channels in both directions. For the 2 VHF stations maybe a Antennas Direct Clearstream 5 or (if you can find it) and Antennacraft CS600.
Are there any trees or do you have LOS (Line-of-Sight) in both directions?
Others will post. Wait until they do before ordering anything.
Old 19-Jun-2015, 5:42 PM   #3
slcole
Thanks for the reply, not many trees close by so basically Line of Sight.
Old 19-Jun-2015, 6:55 PM   #4
rickbb
I think Jake has pointed you in a good direction. (Pun not really intended.)
There are a lot of 1 edge and 2 edge signals in there, you will need to get whatever antenna setup you use as high as possible, (usually higher is better but there are exceptions).
antenna advice, knoxville, tennessee
