Old 22-Apr-2015, 1:08 AM   #1
RiggedToFly01
I got some Channels, Got some questions.
First off, Here is the link.
http://www.tvfool.com/?option=com_wr...f1f09abed0787c
My antenna is the RCA ANT751 Durable Compact Antenna
The above 2 pictures are my setup. I know it's upside down but it allows me to have a full 360 range in my attic. From the antenna there is about 40ft of RG6 to get to the basement where it meets a splitter from there 1 50' run of RG6 to my living room. 1 run of what I guess is RG59 to the Master Bedroom it is in the walls already. I can't imagine it's longer than 50'.
The above picture is taken from below. Which end should I be pointing? The "A" or "B" end?
I have 2 tried random positions so far and I get the channels I need. But I would like to get the most I can. The first position I attempted was the "A" end pointing SW. 16 Channels. The next was turning it 180 degrees. After that 27 Channels. Is there a better way of doing this? Thank you.
RiggedToFly01 is offline   Reply With Quote
Old 22-Apr-2015, 2:04 AM   #2
RiggedToFly01
Old 22-Apr-2015, 2:10 AM   #3
Tim
The 'A' end is the end to point towards the stations you want to receive. Use a magnetic compass (or a compass app on your smartphone) to point towards the magnetic azimuth shown on your TV Fool report for the stations you want to receive.
Old 22-Apr-2015, 11:45 AM   #4
Condense your list down to eliminate all the -2, -3, etc sub-channels since they are part of the same station as their parent channel (-1).
Reduces the clutter for analysis.
Point the small ("A") end towards Farmington and test.
Old 22-Apr-2015, 1:20 PM   #5
RiggedToFly01
Thank you will do on Monday (Day off) and post results
