Old 21-Mar-2015, 10:50 PM   #1
Flint Ridge
Junior Member Wannabe
Running coax in same conduit at 120v
I'm looking to make some antenna/tower upgrades over the next month and in the process I am faced with the question of running separate conduit or run it in the same. What are the interference potentials of doing this? I'm trying to improve reception not introduce a new issue. RG11 shielded cable and a feed line for power, at the tower.
Old 22-Mar-2015, 2:55 AM   #2
Interference shouldn't be a problem but the National Electrical Code doesn't permit sharing power more than 30 volts and signal in the same conduits.
Old 22-Mar-2015, 4:11 AM   #3
Flint Ridge
Ok, good point. I'll bring power from the other direction, which technically is a much shorter run and keep them separate, in case something goes "wrong", I would not want that kind of power.
