Old 17-Mar-2015, 7:27 AM   #1
YPay4tv
OTA Antenna Advice
I would appreciate some advice on a Over-the-Air Antenna to use for the following Signal Analysis. I live in Wilson, NC and want to pick up stations in the Raleigh, NC area that is West of Wilson.
http://www.tvfool.com/?option=com_wr...f1f0136dd7f997
Thanks in advance.
YPay4tv is offline   Reply With Quote
Old 17-Mar-2015, 11:37 PM   #2
If you can avoid obstructions such as trees and structures (including your own), you don't need a big antenna.
The RCA ANT751R pointed west should be able to deliver the signals you specified as well as a few from the SE.
No amplification should be needed to drive a couple of TVs via a passive splitter.
antenna advice, antenna help, hdtv reception, ota, ota antenna
