Old 12-Mar-2015, 1:51 AM   #1
Brentvsmaximvs
Talking Which antenna would work?
I live in Somerset, Kentucky at the southern end of Pulaski County. What I pick up are stations from Knoxville, but I'd like to be able to pick up a few from Lexington.
I have a cheap antenna I ordered from tiger direct - its on a 20 foot pole. I'm wondering if 5 feet more would do the trick?
Any suggestions - my tvfool report is below
thanks
http://www.tvfool.com/?option=com_wr...f1f068af978e22
Brentvsmaximvs is offline   Reply With Quote
Old 12-Mar-2015, 5:04 AM   #2
The report you've posted suggests that you may have access to some Lexington market signals, but the report is flagged as imprecise. Please review this guide: http://forum.tvfool.com/showthread.php?t=14508 then add links for reports for your exact location, based on the current antenna height above ground, 25' AGL and 50' AGL.
Also, can you provide the make & model of your existing antenna? And, do you have a clear view toward Lexington or do you have to aim through trees?
Old 12-Mar-2015, 8:57 PM   #3
Brentvsmaximvs
http://www.tvfool.com/?option=com_wr...f1f08a38216321
Here's my signal analysis - I have a somewhat clear view to Lexington. There are a few hills close by - but it surprises me I'm able to get Knoxville as there are lots of hills to the south east.
My antenna is a Digiwave ANT7287 Super DB8 Adjustable Multidirectional HDTV Antenna from Tiger Direct. I ordered it because it came highly reccomended. I appreciate your help and the signals I do get are really clear.
