Old 7-Feb-2015, 3:19 PM   #1
thesoxwin
Newbie needs antenna help
Western Massachusetts is my location. I am not very tech savvy, but will learn!
Looking to cut the cord by the middle of March, when My DTV sub. ends.
I am going to try to use a eaves mount on the south side of a ranch home. Total height would be about 20'...ground to peak 15 feet and a 5' mast. I have three tv's in the house that I would like to service. They are all new 2012 and up, so I'd imagine they are all set to accept OTA reception.
Any help on selection of a good antenna set-up , would be appreciated.
http://www.tvfool.com/?option=com_wr...2c15639bfa272b
Thanks in advance, Bob
thesoxwin is offline   Reply With Quote
Old 7-Feb-2015, 7:50 PM   #2
WARNING: Address was only resolved to block level and might not be that close to your actual location. For more accurate results, try entering a specific address or coordinates.
Just to be sure we are working with a report that accurately reflects your conditions, please generate a TVFool report based on this method: http://forum.tvfool.com/showthread.php?t=14508
Old 7-Feb-2015, 8:57 PM   #3
thesoxwin
Thanks for the help...this would be my exact location, using the above.
20 ft : http://www.tvfool.com/?option=com_wr...2c153f1951d720
25ft : http://www.tvfool.com/?option=com_wr...2c15ec15070020
30ft: http://www.tvfool.com/?option=com_wr...2c15f7ce67fe3d
Thanks again, Bob.
Old 7-Feb-2015, 9:27 PM   #4
Jake V
It depends on what you want, but if this were me I'd go for the channels at the NE and SSW. Almost all of your stations are UHF. For these I'd use a Antennas Direct DB-8e with one panel at roughly 60 degrees on a compass and the other at 200 degrees.
You have one VHF-HI station (NBC Real Channel 11). It is likely powerful enough to be picked up by your DB-8e. Certainly worth trying before buying anything (like an Antennacraft CS-600). Unless the Antennas Direct VHF Retrofit Kit made for the Clearstream series will work with the DB-8e. I'm not sure.
Wait for the experts to post.
Old 13-Feb-2015, 12:01 AM   #5
thesoxwin
Thanks Jake...will try the DB-8e. Thank you for the help!
Old 16-Feb-2015, 4:23 AM   #6
eden
The Antennas Direct website claims it will work.
eden is offline   Reply With Quote
Old 16-Feb-2015, 11:48 AM   #7
The VHF-1 will clip directly onto the reflector of any ClearStream UHF or 'e'-series UHF antenna. It's actually universal enough to work with ANY UHF antenna when mast-mounted.
As far as if it will work for any given reception challenge, well, that's a completely different question with answers that can be much more complex.
