Old 14-Jan-2015, 1:31 PM   #1
Petawha2
WEPT-CD Missing from zip code 12534 address search
WEPT-CD Digital channel 22 does not show when searching an exact address is zip code 12534
Petawha2 is offline   Reply With Quote
Old 14-Jan-2015, 5:45 PM   #2
When I run a TVFR based on the ZIP code only: http://www.tvfool.com/?option=com_wr...2c159bf77781f6 WEPT-CD shows up...
Please post a link to your TVFR.
Old 14-Jan-2015, 5:47 PM   #3
It's there.
Raise your elevation to 500' and allow the simulator to recalculate. Unless you're behind a mountain, it should show up. If you are behind a mountain, its calculated signal level may be too low to make the cut.
Ninth entry: http://www.tvfool.com/?option=com_wr...2c15daa457c136
