Old 1-Apr-2011, 4:30 AM   #1
Onknight
Geting OTA In Hamilton
http://www.tvfool.com/?option=com_wr...8d17209f49922d
I just Pickup a Digiwav ANT-3045 & Hauppauge WinTV-HVR-850
http://www.digiwavetechnologies.com/..._page&PAGE_id=
http://www.hauppauge.com/site/produc...a_hvr950q.html
So Far I get Two Stations OTA
The Digital Antenna is 5 Foot Off The ground
I will be placing it around 10 FT up once I get the Mounting hardware
I get CHCH 11.1 AND WNLO ON HD
Non HD I get chch and 36
I need some Pointing tips and Motor Help
Onknight is offline   Reply With Quote
Old 2-Apr-2011, 1:46 AM   #2
Use the digiawave to receive the American channels at about 130 magnetic compass. The American channels are more distance away and are not as strong. When the antenna is up higher , the reception is improved. Here are manufactures of real Tv antennas , and have been for a very long time. http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.antennasdirect.com , http://www.antennacraft.com , Here are places to buy Tv antennas and etc. in Canada , http://www.saveandreplay.com , http://www.trentondistributors.com . More information about Canada Tv , http://www.tvtechnology.com/article/105462 , http://www.digitalhome.ca/forum , http://www.friends.ca , http://www.crtc.gc.ca/eng/home-accueil.htm , http://www.canada.com/entertainment/...ion/index.html , http://www.tvzap.com , http://www.titantv.com , http://tv.entertainment.excite.com , http://television.aol.com , http://tvlistings.zap2it.com , Here is how to aim Tv antennas ,http://www.kyes.com/antenna/pointing/pointing.html , Tv transmission and reception is the same in Canada , USA , Mexico , Read and understand this information about , Real Digital Tv Channels , Virtual Digital Tv Channels . Analog Tv Channels , http://forum.tvfool.com/showthread.php?t=695
Old 2-Apr-2011, 2:08 AM   #3
If you know someone that needs a digital tuner , these are recommend . Here are converter boxes to buy in the USA and Canada , http://forum.tvfool.com/showthread.php?t=380
Old 2-Apr-2011, 3:33 AM   #4
Is the building where the the Tv And the antenna are at a , house , condo , apt. , mobile home , motor home ?? The following reduce Tv reception when the Tv antenna is on the inside of the building , Is the building wrapped with but not limited to , metal siding or stucko with stucko Wire ?? , brick from ground to roof , metal foil backed insulation?? , metal roof ?? , solar panels on the roof , poured concrete walls ?? ,
Old 2-Apr-2011, 8:18 PM   #5
Onknight
I got two Station CHCH and WNLO
Both come in well but nothing else
Old 3-Apr-2011, 5:11 AM   #6
Onknight
Obviously the Hauppauge WinTV-HVR-950Q is an analog / ATSC capable tuner, and obviously you are seeing it receive analog and digital signals.
Can you answer the other questions we have posed?
Motor works fine Just having issuing aim it to get good Signal
You can't shut off the Amplified part cause also powers the Motor
I like to get base Stations Fox CBS NBC ABC any Extra would be nice
I don't care about Canadian HD at all not fan of Canadian Feeds
The house is huge 3 Story House I have it the back yard
Also you'll see change to 850 from 950Q
Old 3-Apr-2011, 5:51 AM   #7
The higher the antenna is , the better the reception will be. . I suggest a Antennas Direct 91XG uhf Tv antenna with a Winegard 4700 preamp pointed at the American stations. . The higher a Tv antenna is the better the reception will be. . Outdoor type Tv antennas Like breathing room , no obstructions in the way of the front of the antenna. Tv antennas Like a clear shot at the Tv transmitters.
Old 3-Apr-2011, 5:08 PM   #8
The Higher the antenna is the better the reception will be. The Higher the antenna is the better the reception will be. The higher the antenna is the better the reception will be. Outdoor Type Tv antennas receive the best when nothing is obstructing the antennas view of the Tv transmitters. Outdoor type Tv antennas receive the best when nothing is obstructing the view of the Tv transmitters. Outdoor type Tv antennas receive the best when nothing is obstructing the view of the Tv transmitters.
Old 3-Apr-2011, 6:53 PM   #9
Onknight
Okay guys I need litte Experiment
I took some Fence Wire Bent into a u shape
put Up them on top my Outside Door
attached a connection for coax and Bang Got Signal
WNED HD & DS 19.1 SNR 17.1 & 17.2
WNED 18.1 SNR Jumps all over the place 17.3
WNLO D 23.1 SNR 23.1
CHCH D 29.5 SNR
WKBW D 9.3 SNR No Signal
I am now straight the The Wire Fence and place upright a touch higher
and Report back
Old 3-Apr-2011, 7:08 PM   #10
Higher means HIGHER , not 1 Centimeter higher , Higher means higher in meters and feet , Higher means alot HIGHER , going up and up and up and up and up HIGHER.
Old 3-Apr-2011, 10:10 PM   #11
Onknight
I took UHF part Digiwave antenna off the Rotor Mounting and place it up around 18 Feet
Then took ACU SSR04-S4W Drop Ampifer add added to Cable then into WinTV-HVR-950Q
Old 3-Apr-2011, 10:23 PM   #12
Onknight
This Drawing of how Got it hook up now
I Removed the HDTV Digiwave UHF antenna and as it normal Coax Connection
I am up about 18 Feet Then to back of house and inside to Drop Amplifer
SST-4-s4cw 6kw combo wave surge Protected
s42/53-1000 MHZ Reverse Passive
Here are the Results
Old 3-Apr-2011, 10:38 PM   #13
Onknight
WGRZ 2.1 SNR No 16.3
WGRZ 2.2 SNR No 15.4
WGRZ 2.3 SNR No 15.4
CBLT-DT 5.1 SNR No 18.5
WKBW D 3.4 SNR No 3.6 No Signal or took weak to pick up
CHCH-DT D 11.1 SNR No 27.5
CJXT-DT D 15.4 SNR No 13.2 No Signal or took weak to pick up
WNED-HD D 17.1 SNR No 23.2
WNED-SD D 17.2 SNR No 23.2
WNED-TH D 17.3 SNR No 24.2
WNLO-HD D 23.1 SNR No 30.2
CTS-HD D 36.1 SNR No 26.4
Here are Results from just using HD Ant and Booster inside the house
