Old 5-Jan-2015, 2:47 AM   #1
jcdishar
Requesting help with attic antenna setup
Hello,
I'm looking for a setup to be placed in an attic/crawlspace. The roof is free from obstruction and we are on a hill. The plan is to run cable 45 feet total to the basement to a 1:2 splitter and then 2-20ft runs to HDTVs. I am looking for reccomendations on antennas and any amplifiers needed.
http://www.tvfool.com/?option=com_wr...2c15cd5c914cf2
Looking to get ABC/NBC/FOX/CBS, PBS would be a bonus. Looking for UHF/VHF.
Just looking in general from antennas direct... the DB4e or DB8 and a VHF retrofit but I am open to suggestions.
I currently have a small walmart antenna that sits on top of an end table. We currently receive 8 and 43.
Thank you,
Josh
jcdishar is offline   Reply With Quote
Old 5-Jan-2015, 12:10 PM   #2
DB4e plus VHF-1 should work fine for your major networks. If you want PBS, you'll need to come out of the attic, get the antenna up into clear space, and add an overload-resistant preamp.
Old 5-Jan-2015, 7:03 PM   #3
jcdishar
Thank you for your response.
Unfortunately, it has to stay in the attic. Do you think I will need any type of signal amplifier for that length of cable runs? Or do you think it is a wait and see type approach?
Thanks,
Josh
Old 5-Jan-2015, 7:45 PM   #4
The rest of your stations are of moderate strength. I'd suggest a "wait and see" approach for the amp.
Old 5-Jan-2015, 7:49 PM   #5
rickbb
I too vote an the wait and see approach. I put one in from the get go and found out I did better without it.
