Old 4-Dec-2014, 2:01 PM   #1
dmcnamara
Antenna suggestions for San Rafael CA
Link to TV Fool Report: http://www.tvfool.com/?option=com_wr...d2437ed549785f
Getting tired of cable cost and picture quality so borrowed a Muhu Ultimate from a friend and to my surprise pulled in all channels I wanted with the exception of the NBC affiliate. That station is VHF 2Edge.
So I am inspired to get up on the roof and take a shot at pulling in that station and everything else to the south.
Antenna will be mounted at top or side of chimney.
Looking for suggestions on the antenna setup. Trying to keep it somewhat simple and the towers that I am after are between 132 and 166 degrees.
Thanks in advance!
dmcnamara is offline   Reply With Quote
Old 4-Dec-2014, 4:58 PM   #2
timgr
Is your antenna height on the chimney really going to be 10'? It would be interesting to run another report at the maximum height you figure you can mount your antenna. If you use a chimney mount, you can buy a 10.5' chain link top rail cheap at the local home center and use that for your mast. Should give you 5' or so above the chimney top.
You have a fairly easy distribution of stations, as you have noted. KNTV real channel 12 is a VHF high station, which your little antenna should be much less sensitive to than the UHF stations. KGO 7 is also VHF high, but maybe you can see it because it's stronger. A sensitive VHF antenna will be long/large, to catch the comparatively long wavelength of the VHF band.
If you want to keep things simple, how about one of the HBU series antennas from Antennacraft? http://www.antennacraft.net/Antennas/AntennasHBU.html I would expect that even the HBU11 on a mast would pick up more stations than the Mohu at ground level, and as you go up in size, the antennas sensitivity will increase.
Be sure to pick your antenna location so that it is not obstructed by trees or neighboring buildings in the path of the stations you want.
Old 4-Dec-2014, 5:58 PM   #3
dmcnamara
The TV Fool is based on using a 10' mast - the house is on the downslope of a hill so the top of the chimney is roughly at street level.
I'll look at the Antennacraft HBU line and see what passes muster with the powers that be.
Thanks for the input.
