Old 19-Nov-2014, 8:50 PM   #1
Alan909
Relocating And Need Best Antenna Possible
http://www.tvfool.com/?option=com_wr...d2436b90ced742
I am relocating and like to know a few choices of the best types of antennas and pre-amp to get...the home is a duplex and will be using coax to both sides of home 3 to 4 TV's...not sure how the math works for loss of gain with splitters and coax lengths...I can easily go 35 ft high but does not change much at 15 ft or in between...above is my TVFA...
Alan909 is offline   Reply With Quote
Old 19-Nov-2014, 10:09 PM   #2
timgr
So you want to get the majors from Erie? The majors 24, 12, 50, 22, 16 you should be able to pick up with an AntennaCraft HBU55 or HBU44 http://www.antennacraft.net/Antennas/AntennasHBU.html - Of the pink low power stations, WLEP might be of interest. Unlikely you'll be able to get any of the gray stations. The majors aren't terribly weak, so you should be able to do without an amplifier. I'd try it with a direct wire to one TV and then if you need more amplitude to compensate for added splitters, you can add a mast mounted preamp or a distribution amplifier.
