Old 17-Oct-2014, 4:00 PM   #1
timgr
Chances I can get ...
WENH, by pointing right at it with a Y10713 and preamp?
http://www.tvfool.com/?option=com_wr...d24389d48ebf73
Here it is at 60' - though I don't know offhand how I'd get that much height.
http://www.tvfool.com/?option=com_wr...d24362db9b2e41
Old 17-Oct-2014, 7:37 PM   #2
The predicted signal at 40' is too low for a single Y10-7-13. However, if the transmitted antenna pattern favors you and your terrain is favorable you might be able to find a height that works. You could consider a pair of the same antennas stacked and then expect to find the optimum height by trial and error.
Old 19-Oct-2014, 1:31 PM   #3
StephanieS
That little red co-channel scares me. What does WENH look like at 100'?
Even if you get it up to usable strengths, that co-channel might torpedo the thing.
SS
Old 19-Oct-2014, 4:13 PM   #4
I see no reasonable prospect of getting that station. The desired incoming signal is too weak and will buried in the background noise most of the time.
Old 19-Oct-2014, 4:17 PM   #5
timgr
Here it is at 100' - becomes LOS. http://www.tvfool.com/?option=com_wr...d243dabb5b2226
Funny - I don't see any other channels on the list broadcasting on 11.
Old 19-Oct-2014, 10:14 PM   #6
StephanieS
Lookee there, it indeed pops LOS and useable strength at 100'. Maybe backtrack and see at what height it pops LOS, say 70'/80'/90'.
It may be possible at higher heights to get a usable signal. Question is are you willing to install a tower to get it?
Old 19-Oct-2014, 11:26 PM   #7
timgr
It's still 2-edge at 80, but a NM of 17. One edge at 85 and LOS at 90.
No tower this year ...
Old 20-Oct-2014, 5:17 PM   #8
Ben Myers
KD3WB
It's not on the list, but possibly WWLP in Springfield Massachusetts. Springfield also has a PBS affiliate, WGBY, real channel 22. Even closer are WGBH and WGBX in Boston and WSBE in Providence. Concerning WENH, I suggest you simply try to find a hot spot, especially if you will be using a dedicated antenna for the station.
