Old 5-Oct-2014, 7:02 PM   #1
jim97gst
Antenna Recommendation
I would like an antenna recommendation based on the report linked below. I can do a roof top antenna if necessary. It's a 2 story house so the antenna would be at approximately 25 feet above grade.
Thanks in advance.
http://www.tvfool.com/?option=com_wr...d24351f18ee197
jim97gst is offline   Reply With Quote
Old 6-Oct-2014, 12:05 AM   #2
StephanieS
Greetings Jim,
Lovely amount of signal access you have. If you have a clear unobstructed view towards magnetic 50, I would feel fine in installing an Antennacraft HBU11k to that heading.
How many TVs would you like to be fed by the antenna?
Cheers
Old 6-Oct-2014, 12:16 PM   #3
jim97gst
Probably 4. This is a house I'm in the process of buying but haven't moved in yet so I don't know how the coax cable is run yet.
Old 21-Oct-2014, 1:36 AM   #4
jim97gst
Stephanie, thanks so much for your help. I'm moved into the house now and I think I can get the antenna just above a hill that's at 51 deg if I get it on the highest part of the roof. If I can't get it above that hill do you have a different recommendation? I'd rather spend a little more and try and get as many channels as possible without having to try a different antenna.
Jim
