Old 3-Oct-2014, 1:38 AM   #1
eMikey
Threw the dish off of the roof, whats my best bet now? Waterbury, Ct.
What antenna/combination should I get for maximum channel count? I could care less about spanish stations.
I plan on 3 TVs with approx 50 total of coax. Would I need a preamp?
Thank you
30ft
http://www.tvfool.com/?option=com_wr...d24313349959ef
60ft
http://www.tvfool.com/?option=com_wr...d2432f4530d71e
eMikey is offline   Reply With Quote
Old 3-Oct-2014, 7:56 PM   #2
I'd use two antennas.
An Antennas Direct DB8E facing NE and an Antennacraft Y5713 pointed at real CH 10 (to the SE).
I'd try this with no preamp... You're right at the point where overload may be an issue on the stronger signals.
If the need is proven, a distribution amplifier such as the Channel Master CM-3410 can be added at a convenient point between the antennas and passive splitter.
You'll also need a UHF/VHF combiner. The Antennas Direct option includes a weather proof housing. https://www.antennasdirect.com/store..._combiner.html
