Old 20-Sep-2014, 3:40 PM   #1
Dave Taylor
Antenna Help Please
This link:
http://www.tvfool.com/?option=com_wr...d243afeceaf5a3
is what I receive from "TVFOOL" for an external atenna at 30'.
What atenna setup (type/make/model/style) do you folks recommend for the best reception of the most HD digital TV channels?
Dave
Dave Taylor is offline   Reply With Quote
Old 22-Sep-2014, 9:31 AM   #2
StephanieS
Hello Dave,
Rough report I am afraid. The only good signal you have is K25NK-D which reports religious programming. KTTC NBC from Rochester on RF 10 is very weak. WKBT CBS on RF 8 from La Crosse is in the same boat and it gets worse quickly.
Your plot is currently at 30'. I would create new plots based on 50' and 100' elevations. At 30', it is doubtful you would have reception that you'd be happy with.
The goal with the new reports would be to see if the La Crosse/Rochester signals get up in the 10 - 15 (nm)db range. Then we can work with them.
You may find an investment in a tower or tree mount may be called for here.
Cheers.
Old 27-Sep-2014, 7:44 AM   #3
Dave Taylor
Thank you Stephanie,
It would appear that your analysis of the analysis is spot on.
Will you please expand on your "tree mount" idea?
The location is built into a hillside and faces (is open to, I believe) the northeast.... and has trees on the hillside behind and well above it.
Thank you
Dave T
Old 27-Sep-2014, 11:51 PM   #4
StephanieS
Hi Dave,
Tree mount information can be found here:
http://www.ronard.com/tree.html
Here's an example of someone's set up:
Normally, you'd remove the top 5 or 6' of a tree so you can get a clear mounting situation and ideally a clear unobstructed line of sight in the direction of the transmissions you want.
Before you get to far into entertaining this scenario though, make a TV fool plot based on the projected height of a tree that would be your candidate do this. The goal would be to gain access to enough signal to make the installation worth it
Cheers.
