Old 25-Mar-2011, 4:48 PM   #1
blakeseven
Help with Digital antenna Purchase
Hi All
I want to move to OTA andfwwd my Media center with a HD home Run.
What set up should I get. I can go on the Roof or in the attic. I have a DTV Dish on the roof and would like to use that mount if possible.
Here is my report.
http://www.tvfool.com/?option=com_wr...8d17fb83331fb0
Thanks in advance for any help
blakeseven is offline   Reply With Quote
Old 26-Mar-2011, 2:51 AM   #2
Read and understand this about , Real Digital Tv Channels , Virtual Digital Tv Channels , Analog Tv Channels , http://forum.tvfool.com/showthread.php?t=695 Here is how to point Tv antennas. The 'Outdoor Type' Tv antenna must be level with the ground , not pointed at the sky , not pointed at the ground , the antenna must not be cocked at odd angles. http://www.kyes.com/antenna/pointing/pointing.html
Old 26-Mar-2011, 7:09 AM   #3
My experience with the HD HomeRun has been quite positive. I would recommend an antenna such as the Winegard HD7694P, aimed at about 46° compass.
Old 27-Mar-2011, 3:20 AM   #4
blakeseven
Thanks for your help.
Will I need asa pre amp or a uhf antenna?
Old 27-Mar-2011, 3:35 AM   #5
You should not need an amplifier. Many amplifiers would be overloaded in your situation.
The HD769X series antennas are combination UHF / High-VHF antennas. They are designed to receive real channels 7 through 69.
Old 28-Mar-2011, 8:24 PM   #6
Here are some online Tv guides , http://www.titantv.com , http://television.aol.com , http://zap2it.com , http://tv.yahoo.com , http://tv.entertainment.excite.com , http://tvzap.com
