Old 4-Sep-2014, 1:51 AM   #1
gobblerman601
help choosing an antenna setup
http://www.tvfool.com/?option=com_wr...d243741721eaa5
I currently have one of thes cheap antennas. http://www.amazon.com/gp/aw/d/B004NQ...pf_rd_i=mobile
I recieve channels 7- 11-14-19-22-34 but would like to recieve as many channels as possible any antenna amplifier or splitter suggestion will help I want the best I can get
Thanks in advance
gobblerman601 is offline   Reply With Quote
Old 4-Sep-2014, 1:53 AM   #2
gobblerman601
Also what are my options for running 2 directional antennas and a a-b switch
Old 5-Sep-2014, 5:57 AM   #3
An A/B switch is not required.
A antenna rotator is not required.
Above the Peak of the Roof in such a manner that the roof and building are anot , obstructing , impeding , blocking , reception in the directions of , South , West , North West , North.
Install a , Antennas Direct , DB8e , Current UHF channels 14 thru 51 antenna.
Aim 1 panel at about 195 degree magnetic compass direction.
Aim the other panel at about 258 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone or tablet and etc. compass.
As always , the antenna aim direction and antenna location can be adjusted for best reception.
About 3+ feet below the DB8e antenna install a.
http://www.antennacraft.net.
Y5-7-13 , VHF high band channels 7 thru 13 antenna aimed at about 278 degree magnetic compass direction.
Install a.
10G221 preamplifier.
Connect the DB8e antenna to the UHF connection of the 10G221 preamplifier.
Connect the Y5-7-13 VHF antenna to the VHF connection of the 10G221 preamplifier.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com/909911.html. Install the 3 foot or 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length - 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe. The price is low at about 12 dollars.
For the Best Reception avoid aiming the antennas in to trees and other obstructions in the directions of reception.
