Old 28-Aug-2014, 9:19 PM   #1
tboneBill
Rochester, NY Antenna
I am interested in the best approach for this location, mixed high-VHF/UHF. I am only interested in the 5 green digital LOS channels at 130 degrees.
http://www.tvfool.com/?option=com_wr...ec2f777d57906f
This will go to one TV only. Thank you!
tboneBill is offline   Reply With Quote
Old 28-Aug-2014, 10:15 PM   #2
I'd use something like the RCA ANT-751 or Antennacraft HBU-11.
Old 29-Aug-2014, 1:49 AM   #3
tomfoolery
I'm about the same distance, but on the other side of Rochester, with a similar TVF report. I use a DB4e in the attic (lousy place for an antenna) with a dipole for high-VHF and all stations are 100%. I installed an HBU22 for my inlaws, aimed right into a giant hedge so thick you can't see daylight out the other side (no other location available), and same strong result.
Transmitters are on Pinnacle Hill, where I-490 crosses Monroe Ave. If it's a clear shot, outdoors and without obstruction or heavy foliage, I would think an HBU11, ANT751, or a C2V should be all you need.
