Old 28-Aug-2014, 8:17 PM   #1
beamsplint
Help with antenna setup in Windsor, Ontario
Hello,
I'm looking for some advice on setting up an antenna in Windsor, Ontario.
My TV Fool: http://www.tvfool.com/?option=com_wr...ec2f6ebc494624
I'd like to be able to get CKCO #42 and CIII #22 and CBET #9 plus the Detroit stations. The house is a brand new 2-storey and the antenna will feed a single HDHomeRun receiver in the basement (about 40 feet away).
Thanks,
beamsplint is offline   Reply With Quote
Old 29-Aug-2014, 6:54 AM   #2
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , in All Directions.
Install a.
http://www.antennacraft.net.
HBU11K antenna.
Aimthe HBU11K antenna at about 300 degree magnetic compass direction.
Here is how to aim antennas.
Also to assist in obtaining the Best Reception most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
Install a.
10G201 preamplifier.
If the signal is split 2 or more ways.
Use a , Holland Electronics , HFS-2D , 2 way splitter.
Use a , Holland Electronics , HFS-3D , 3 way splitter.
Use a , Holland Electronics , HFS-4D , 4 way splitter.
Here are some alternatives to the HD HomeRun at some or all locations in the building.
http://www.epvision.com.
Here are some places to buy antennas and etc. in Canada.
http://www.saveandreplay.com.
Know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
