Old 19-Aug-2014, 11:31 AM   #1
alfred67
antenna advice
Hello
Thinking of buying RCA ANT751 mount outside and 14 feet above the ground would this work for me or is there a better setup. Looking to receive channels in green and Yellow, the ones in grey may be fine if the antenna is not to big
My signal analysis report is at http://www.tvfool.com/?option=com_wr...ec2f3ddfa7f63c
Alfred67
alfred67 is offline   Reply With Quote
Old 20-Aug-2014, 12:11 AM   #2
The ANT751 antenna will most likely work Ok at your reception location.
The ANT751 antenna is designed to receive the VHF high band channels 7 thru 13 and the Current UHF band channels 14 thru 51 the best.
Your reception location does have 1 VHF low band channel , channel 2 , CHBX-TV , CTV , is Very Strong Signal Strength , and will be received by the ANT751 antenna because the Signal Strength Is So Strong.
The weakest signal strength Tv station is WGTQ-DT , Real VHF high band channel 8 , ABC and NBC.
Aim the ANT751 antenna at WABQ.
Aim the ANT751 at about 167 degree magnetic compass direction.
Here is how to aim antennas.
As always , the antenna aim and location can be adjusted for best reception.
A antenna system amplifier will most likely not be required for , 1 , 2 , 3 , Tv's connected.
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own , attic , roof , building.
The directions of reception at your location are , South South East and North East.
Install the ANT751 antenna at a location that is clear of obstructions in the directions of reception.
Tvfool is showing that your reception location has a mix of.
NTSC Analog broadcast Tv station channels.
CHBX-TV Real VHF low band channel 2 , CTV.
and
CHCH-TV Real UHF band channel 38 , Independent Super Station.
ATSC Digital broadcast Tv stations channels.
CIII-DT Real UHF band channel 15 , Global.
WWUP-TV Real VHF high band channel 10 CBS and FOX.
WGTQ-DT Real VHF high band channel 8 ABC and NBC.
The Tv will need to channel scan for.
NTSC Analog broadcast Tv channels.
and
ATSC Digital broadcast Tv channels.
DO NOT Channel Scan For Cable Tv Channels.
Last edited by teleview; 21-Aug-2014 at 9:17 AM. Reason: Clarify information and typos.
Old 20-Aug-2014, 4:19 PM   #3
alfred67
Thanks for the reply teleview.
Is there an another antenna that would work better??
What antenna could I use to go with attic mount antenna
Alfred67
Old 21-Aug-2014, 11:33 AM   #4
alfred67
Alfred67
Old 22-Aug-2014, 5:57 PM   #5
alfred67
Hello
Would a Antennacraft 5884 ColorKing 58" work for me in my attic?? It's to big to put outside wife would kill me
Alfred67
Old 22-Aug-2014, 6:53 PM   #6
The Truth is.
Antennas are Beautiful and Handsome.
Know this.
Hiding antennas is a good way to get less reception.
Here is/are more facts and information.
As always , attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
The truth is.
The only way to discover if reliable reception will happen in the attic is to install a antenna in the attic.
The 1 advantage of the antenna in the attic , is the antenna will last a long time.
Most likely you are recommending the Antennacraft 5884 antenna because it is a All channel antenna that is designed to receive channels 2 thru 51.
Your reception location has receivable Tv channels in each of the 3 Tv channel bands.
The Current UHF band channels 14 thru 51.
And the 5884 antenna is available at a local store.
Yes the 5884 antenna is a very good antenna for reception at your location.
I am not saying that reception will be difficult with the ANT751 installed outside in the clear of obstructions.
Last edited by teleview; 26-Aug-2014 at 7:32 AM. Reason: Clarify information and typos.
Old 23-Aug-2014, 11:45 AM   #7
alfred67
This is exactly what I was thinking.
Trying to find a good antenna for my area without over kill.
What would be your recommendation for an outside antenna??
Alfred67
Old 25-Aug-2014, 1:01 AM   #8
The , http://www.antennacraft.net.
HD850 All channel antenna is a Heavy Duty long lasting antenna.
The Antenna Craft , C290 and 5884 All channel antennas will also be Ok.
Also the.
The , CM3016 All channel antenna.
http://www.saveandreplay.com.
Old 13-Sep-2014, 9:49 PM   #9
alfred67
Hello
I decided to buy RCA ANT751 and its pointed at WGTQ-DT seems to work well.
Channel 2 does come in but very shadowy anyway to clear this up??
Channel 38 CHCH-TV is unwatchable would a preamp help??
Alfred67
Last edited by alfred67; 13-Sep-2014 at 9:51 PM. Reason: added TV Signal Analysis link
