Old 18-Aug-2014, 7:34 PM   #1
ImmortalThanos
ImmortalThanos's Avatar
Triad NC Signal Help
Hello everyone. I finally cut the cord in May of this year after being a 15-year Dish Customer. It was a fantastic decision, but I'm still working out a few problems with my OTA reception. Namely, I can not receive my local NBC (WXII) or Ion (WGPX) affiliates. Here's my TV Fool Signal Analysis Report:
http://www.tvfool.com/?option=com_wr...ec2f116e3b64ba
I have a ClearStream 2 Long Range Indoor/Outdoor DTV Antenna mounted near the southeastern corner of my home on a 7-foot pole. It picks up all other local Triad affiliates perfectly as situated. I have it facing to the west. When looking at the signal strength on my TiVo box, it can sense that WXII and WGPX are there and register a pretty decent signal, but not enough of one to lock them in.
If I turn the antenna to the east, I can pick up many Raleigh affiliates, but still no NBC or Ion. If your advice can help me lock a complete swathe of broadcast affiliates from the Raleigh area, I'd be willing to do it. I'm local to Greensboro, but it's not a big deal.
Thanks for your time and assistance.
ImmortalThanos is offline   Reply With Quote
Old 18-Aug-2014, 9:55 PM   #2
Install the , Clear Stream 2 , antenna Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked by the , attic , roof , building , in the directions of reception.
Know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing Blocking Reception.
The Best Practice for Reliable Reception is to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
The directions of reception at your location are , West , North West , North , South West , South East.
Here are some , Strong , Sturdy , Long Lasting , above the roof antenna mounts.
The Ronard antenna mounts are Over Built so as to Last a Long Time.
http://www.ronard.com/909911.html. Use the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224).
http://www.ronard.com.
Home Depot , has 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that make excellent antenna mast/pipe , the price is low at about 12 dollars.
Aim the CS2 antenna at about , 344 degree magnetic compass direction.
Here is how to aim antennas.
Most Digital Tv's have a Signal Strength Meter and Some Digital Tv's also have a Signal Quality Meter.
As always , the antenna aim and location can be adjusted for best reception.
If the , Clear Stream 2 , antenna has the 2 UHF reception loops for reception of the Current UHF channels 14 thru 51.
And has no VHF channels 7 thru 13 , metal rod type reception elements.
Contact.
Order and install the , VHF Reception Kit , for reception of VHF high band channels 7 thru 13.
A antenna system amplifier will most likely not be required for , 1 , 2 , Tv's connected.
For more then 2 Tv's connected install a.
http://www.antennacraft.net.
10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at.
or
http://www.amazon.com
Digital Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
To keep Weather/Water out of outside coax connections and devices.
Use coax that has the Compression Type Connectors on the ends of the coax.
Do not use the old type , crimp type connectors.
Do not use coax that has the , molded on the coax type connectors.
Snug Tight coax connections.
To make Double Sure that Weather Water does not get into outside connections wrap with , http://www.coaxseal.com
Last edited by teleview; 19-Aug-2014 at 6:43 AM. Reason: Clarify information and typos.
Old 19-Aug-2014, 12:58 AM   #3
You will need to aim the antenna to the north northwest with a decent line of sight to pick up those two stations. Make certain the antenna isn't aimed point plank into your own roof, your neighbor's house, or a big tree. Get the antenna up in the air while you're at it if you used a satellite dish yard mount post.
Old 19-Aug-2014, 2:08 AM   #4
ImmortalThanos
That may be why I'm not picking up those two stations, then. I can't aim the antenna to the northwest because my house would be right in the way. Could the stations' signals potentially be strong enough to penetrate through my home?
Old 19-Aug-2014, 8:12 AM   #5
Stereocraig
You can try it, but don't expect miracles.
You're much better off, just mounting it correctly the first time.
Some signals may already be borderline, so there's really no need to aggravate a situation that you have perfect control over.
Old 19-Aug-2014, 1:12 PM   #6
ImmortalThanos
When you say "mount it correctly the first time", what do you mean?
As to "aggravate the situation", I don't follow what you're implying either.
Thanks.
Old 19-Aug-2014, 3:33 PM   #7
Stereocraig
Thanks.
Mount the antenna above the house.
To expect a signal to travel through a house, is a crap shoot, at best.
You are already having problems receiving stations. Don't make it worse, by blocking the signal.
I'm simply reinforcing what has already been said.
