Old 8-Aug-2014, 11:46 PM   #1
Few39
Mountain Service
I live in the mountains of NC and am thinking there isn't much hope of me getting free signals. Any suggestions would be appreciated!
Elyse
http://www.tvfool.com/?option=com_wr...e1c63ee70a0b57
Few39 is offline   Reply With Quote
Old 9-Aug-2014, 12:10 AM   #2
It looks as if you would be able to receive one or more versions of PBS affiliate programming... I doubt much else can be received reliably given the mountainous terrain between you and the other stations.
If you want to try, I'd suggest an Antennas Direct DB4e facing east (about 80° per a real compass).
Old 9-Aug-2014, 12:13 AM   #3
Few39
That's what I was afraid of. Thanks for confirming.
Old 9-Aug-2014, 8:28 AM   #4
The provided tvfool report shows No antenna height above ground.
Do not delete the first tvfool report that shows no antenna height above ground.
To see if signal strengths improve at higher antenna heights above ground
please make and post 3 more tvfool reports with antenna heights of , 25 feet ,
40 feet , 60 feet , antenna heights above ground.
