Old 4-Aug-2014, 11:10 PM   #1
Dallasgirl
Moved and need another OTA
Digging up this old thread. (http://forum.tvfool.com/showthread.php?p=45491), I have since moved and need help with a new antenna. Here are my details.
http://www.tvfool.com/?option=com_wr...e1c65292b2c3cd
I would like to place in the attic if possible.
Btw I love cutting that cord!
Thanks in advance,
Jill
Dallasgirl is offline   Reply With Quote
Old 5-Aug-2014, 12:11 AM   #2
A Simple Reception Situation.
Attics and the Inside of Buildings Are Not a reception friendly location and Never Will Be a reception friendly location.
Yes you can install a ,
http://www.antennacraft.net.
HD850 antenna in the attic aimed at about 235 degree magnetic compass direction.
If reception situations happen in the attic that are not resolvable with antenna aim adjustments and antenna location adjustments in the attic , then move the antenna to above the peak of the roof.
Old 13-Aug-2014, 2:38 PM   #3
Dallasgirl
Teleview: I will look at that Antenna.
Thank you!
Old 13-Aug-2014, 3:12 PM   #4
Dallasgirl
Oh if I choose to split to 4 tv's do I need any additional equipment?
Thanks again!
Old 13-Aug-2014, 3:32 PM   #5
tomfoolery
If size is an issue, and/or if you don't care about real 2 and 4 (infomercials and off the air, per rabbitears.com), an HBU33 has the same gain on UHF and slightly more gain on high-VHF. Just another option. The HBU33 is 43-1/2" wide and the HD850 is 111" wide, and both are 85" boom length.
Old 13-Aug-2014, 4:03 PM   #6
Dallasgirl
Interesting....a quite a bit smaller in width, lighter and cheaper.
Thanks for the alternative. I will check that one out too.
Old 13-Aug-2014, 5:16 PM   #7
Stick with the narrower antenna. There's nothing on the air in Dallas that requires the wider one.
Old 13-Aug-2014, 10:06 PM   #8
As I understand it. It is not my place to tell Dallasgirl what is of interest for Dallasgirl to receive or not receive.
I see that others here at Tvfool , see it as their place to tell Dallasgirl what Dallsgirl can and can not receive.
Dallasgirl , might like to receive.
KHFW-LD low band Tv channel 4 , infomercials.
KSFW-LD low band Tv channel 2 , Religion programing.
The HD850 antenna is designed for reception of--> All Tv Channels.
Both of these Tv stations are for sale.
As is-->true<->of other Tv stations here in the USA and around the world are for sale.
The New Owners will most likely change the Network programing to some other Network/s , as often happens when Tv stations are sold.
The Network/s on the Tv/s stations may or may not be of interest now and the Networks may or may not change to something of more interest.
Last edited by teleview; 15-Aug-2014 at 9:21 AM. Reason: Clarify information and typos.
