Old 5-Aug-2014, 1:46 AM   #1
Hungry_Jo
Advice for antenna and orientation
Hi,
I would like some help/advive on an antenna and orientation plz.
Here is my signal analysis :
http://www.tvfool.com/?option=com_wr...e1c609ad5235e9
I presently have a 4 bay bow tie on my roof that is 2 floors up (don't know brand). I get all the canadian channels all right, but i would like to get more USA channels.
I get CBS fine and NBC is so-so.
I don't get ABC and Fox and would to get them.
I have my antenna set up on a corner of my house and have a tent shape roof. The antenna is on north-East Corner and I could put it on the other corner in the back, so South-East Corner
Any advice ?
Thanks in advcance for the help !
My oncle has a double 4 bay bow antenna, would that help instead ?
Jo
Hungry_Jo is offline   Reply With Quote
Old 5-Aug-2014, 11:24 AM   #2
Billiam
You will need a stronger antenna (fringe or deep fringe model) and probably a rotor to obtain any signals in red.
Old 5-Aug-2014, 2:08 PM   #3
Ben Myers
KD3WB
If you are trying to get ABC on WVNY in Burlington, it's on real channel 13, and you'll probably need an antenna with Hi-VHF capability. If you have rabbit ears or any indoor antenna, you might try it. Hot spots often work with simple antennas and just confirming that a signal is present is a step forward. Fox on WFFF, also in Burlington is on real channel 43 and in the same direction as NBC and CBS. I would try raising or lowering the existing antenna instead of moving it. I suggest you try to find a way to tune the TV to real channel 43 and watch or have someone else watch the TV during the adjustment.
Old 5-Aug-2014, 3:22 PM   #4
Disconnect and remove any antennas that are connected.
Disconnect and remove any antenna system amplifiers that are connected.
Disconnect and remove splitters.
For reception of USA Digital Broadcast Tv Stations/Channels and Canada Digital Broadcast Tv Stations/Channels.
A antenna system rotator is not required.
The antenna is aimed at the Weak Signal Strength USA Digital Broadcast Tv Station/Channels , and the Strong Signal Strength Canada Digital Broadcast Tv Station/Channels will be received at/through the back angle of/to the antenna.
Install a ,
http://www.antennacraft.net.
HBU44 antenna.
Aimed at about 156 degree magnetic compass direction.
Here is how to aim antennas ,
http://www,kyes.com/antenna/pointing/pointing.html.
As always the antenna aim direction and antenna location can be adjusted for best reception.
Install the HBU44 antenna above the Peak of the Roof in such a manner that the , attic , roof , building , are not , obstructing , impeding , blocking , reception in the directions of , South East , South , South West , East , North East.
Install a ,
10G201 preamplifier.
For 1 tv connected use No splitter.
Here are some Above Peak of Roof antenna mounts.
http://www.ronard.com/909911.html . Install a , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html . Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2214) .
http://www.ronard.com.
Home Depot has , 10 foot 3 inch length , 1 and 1/4 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe.
http://www.saveandreplay.com.
Also know this.
Trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
The Best Practice for Reliable Reception is to install the HBU44 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , trees , plants , attic , roof , building .
