Old 5-Aug-2014, 12:48 AM   #1
jackson
Newbie and wanting recommendations
http://www.tvfool.com/?option=com_wr...e1c6ca53925535 Living in Toledo,Ohio,I am wanting to pick up Toledo and Detroit channels without a rotor.Perhaps 2 antennas on separate gables about 25' high with cable runs of about 40'.I know there are only a few vhf channels but would like to pick them up anyway.Thanks.
jackson is offline   Reply With Quote
Old 5-Aug-2014, 6:40 AM   #2
A Simple Reception Situation.
A antenna rotator is not required.
Detroit and Toledo , Digital Broadcast Tv Stations/Channels will be received.
Above the Peak of the Roof install a HD1200 All Channel Antenna in such a manner that the , attic , roof , building , are not , obstructing , impeding , blocking , reception in the directions of , South East , South , North East , West.
http://www.antennacraft.net.
HD1200 All Channel Antenna aimed at about 45 degree magnetic compass direction.
As always , the antenna aim can be adjusted and the antenna location can be adjusted for the best reception.
Install a ,
10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com/909911.html . Use the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , Use the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html . Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Also know this.
Trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and obstructions in the directions of reception including your own , attic , roof , building.
For Reliable Reception install the HD1200 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building .
Last edited by teleview; 10-Aug-2014 at 8:39 AM. Reason: Clarify information and typos.
Old 5-Aug-2014, 12:49 PM   #3
elmo
So now that the water is flowing again, it's time to figure out some TV!
So your locals would be pretty easy to pick up with an antenna that can get down to VHF-Hi. (Unless WLMB is of any interest, because it's a VHF-Lo.) An HBU-11 or ANT-751 would do a good job and be easy to mount on the house facing SE.
Going after Detroit will take some more metal and a really good line of sight to the NE. And even then, reception won't compare to the quality of the Toledo signals. Is there a particular Detroit channel you want? But before really looking into that, what's your plan for combining two antenna signals? You cannot just reverse them thru a splitter w/o degrading everything. You'd need a TV or tuner with dual coax inputs so you could switch as needed. If you are into computers as HTPC devices, then an HDHomerun would be perfect to seamlessly put the channels together with no impact at all.
Old 7-Aug-2014, 12:10 AM   #4
jackson
Thanks for your reply,the boneheads at the water plant decided to add more chlorine after more than 100 people went to the hospital with diarrhea .I have been looking at that HD homerrun and pitching the cable box.As far as picking up Detroit,I was thinking about the RCA ant3038xr since I can get this at Menards for about $95.00.
