Old 3-Aug-2014, 3:31 PM   #1
krames
Looking for more signal!!!
Hey everyone,
I recently cut the cord and I am currently using a mystery 3 foot attic antenna that was left by the previous homeowners. This antenna is currently pointed at 210 degrees and it is perpendicular to an attic vent. My antenna immediately leads into a two way splitter that feeds into two 50 foot runs. My house is a one story brick house with an asphalt roof. With this current configuration, I get in ABC, And PBS pretty well. FOX breaks up occasionally. NBC and MyN are a total loss.
I tried using a Winegard Boost XT LNA 200 to increase my signal and it actually impacted the signal coming from PBS and FOX.
I just ordered a Winegard HD Outdoor Antenna FL6550A which I am planning to try to install on the roof. I would like to get in ABC, PBS, FOX, NBC, and MyN. I would also like to try to get in ION and CW, but that's not quite as important. Will this antenna work? Is there a better one to get for my situation?
http://www.tvfool.com/?option=com_wr...e1c6823e92cc6c
Thanks in advance!
Kyle
krames is offline   Reply With Quote
Old 3-Aug-2014, 3:47 PM   #2
Billiam
The amplifier in the antenna you just purchased may overload some of your signals. You don't need a pre amp for any stations in Green.
Old 3-Aug-2014, 5:53 PM   #3
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in all directions , install a.
http://www.antennacraft.net.
AC9 antenna
aimed at about 170 degree magnetic compass direction.
Here is how to aim antennas , http://www.ktes.com/antenna/pointing/pointing.html.
As always , the antenna aim and location can be further adjusted for best reception.
A antenna system amplifier is not required for reception.
Buy the , HFS-2D , 2 way splitter at ,
http://www.hollandelectronics.com , or , http://www.amazon.com.
Here are some and not all antenna mounts.
http://www.ronard.com/909911.html . Install a , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html . Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html . Measure around the chimney and use a , ronard(2212) or ronard(2218) or ronard(2224) .
Home Depot has , 10 foot 6 inch length , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
Also know this.
Trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own , attic , roof , building.
Absorbing Blocking Reception.
The Best Practice for Reliable Reception is to install the AC9 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
At your reception location the directions of reception are All Directions.
