Old 1-Aug-2014, 5:41 AM   #1
rnelson
Antenna
Noob to ota. Looking for indoor OR outdoor antennas that would be best for me using my plot attached.
Running two HDTV's. Difficult aiming antenna due to some tree and branch obstructions. Currently using a RCA ANT751R outside with no preamp. Getting good reception. Just want to know if it can get even better.
rnelson is offline   Reply With Quote
Old 1-Aug-2014, 4:54 PM   #2
Concerning the Tv Stations to the , East North East , East , South East.
Are all of the Tv stations in the Green reception zone being received reliably??
Are all of the Tv stations in the Yellow reception zone being received reliably??
If not , what Tv stations are not??
The tvfool radar report and channel list is a , 'picture' , of a tvfool radar report and channel list report.
Is not a live and active tvfool radar report and channel list.
Is best to provide a Live and Active tvfool radar report and channel list.
The Current Tv Stations/Channels that are Transmitted and Received in the , USA , Canada , Mexico , are.
VHF low band channels , 2 thru 6.
VHF high band channels , 7 thru 13.
Current UHF band channels 14 thru 51.
Your reception location has receivable Tv Stations/Channels in all 3 Tv channel Bands.
Recommend install a All Channel Antenna , Antennacraft HD850 .
The ANT751 antenna is designed for reception of VHF high band channels 7 thru
13 and the Current UHF channels 14 thru 51.
A antenna upgrade for your reception location is the.
http://www.antennacraft.net.
HD850 , All Channel Antenna that receives , VHF low band channels 2 thru 6 ,
VHF high band channels 7 thru 13 , Current UHF band channels 14 thru 51.
Aim the HD850 antenna at about 85 degree magnetic compass direction.
Install the HD850 antenna at a location that is not obstructed by trees and tree
leaves , plants and plant leaves , and all other types and kinds of obstructions ,
in the directions of reception to the , North North East , East , South East , including the obstructions of your own , attic , roof , building.
Here are some and not all antenna mounts to install a antenna above the peak of the roof so reception is not , obstructed , impeded , blocked , buy the , attic roof , building , in the directions of reception.
Install the , ronard(911) , 5 foot tripod antenna mount.
Install the , ronard(4560) , eave antenna mount.
Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
Home Depot has , 10 foot 6 inch lengths of 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes good antenna mast/pipe , the price is low at about 12 dollars.
A antenna system amplifier is most likely Not required.
However can , 'Test Reception' , without and with a preamplifier.
10G201 preamplifier.
Buy the , HFS-2D , HFS-3D , HFS-4D , splitters at , http://www.holladelectronics.com , or , http://www.amazon.com.
Digital Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
http://www.wchstv.com/DoubleReScanAlert
Old 1-Aug-2014, 5:09 PM   #3
Jake V
You have a lot of channels in the "green" zone that you probably receive if your antenna is pointed roughly at 65 degrees. You will want to post a list of channels that you currently receive before anyone can comment on if you can do better.
