Old 30-Jul-2014, 8:33 PM   #1
tpampane
Need your help with getting Channel 13 WLOS from attic antenna
Hello Everyone, I am in need of your support. I want to install an antenna and say good bye to my local cable company. I have purchased several off the shelf antenna's from walmart with good results. The one channel that I am not able to pick up is WLOS channel 13 ABC. Based on the color legend it recommends that in order to pick up this channel I will more than likely need to install an antenna on my roof. I prefer not to do this but rather install in my attic.
The off the shelf antenna's that I have tried provide great reception with 80-100% signal strength with the excepton of channel 13. I would like to get your advise on how I can overcome this obstacle with placing the right antenna in my attic. I am willing to invest in a good antenna that I can place in my attic to include getting channel 13. Any advice that you can help will be greatly appreciated. I look forward to your response. My TV signal results are attached at the URL listed below.
Thanks in advance!
http://www.tvfool.com/?option=com_wr...e1c62c5d9dda68
tpampane is offline   Reply With Quote
Old 30-Jul-2014, 10:17 PM   #2
The provided tvfool report shows no antenna height above ground.
Do not delete the tvfool report that shows no antenna height above ground.
To see if the reception situation improves.
Please make and post a tvfool report with the Exact address and make the antenna height in the tvfool report 25 feet above ground.
A antenna height of 25 feet above ground is a Reference antenna height that provides a good evaluation of what is receivable.
Old 30-Jul-2014, 11:15 PM   #3
WLOS is going to require a serious high-VHF antenna outside, up in the air...plus some luck that you don't encounter localized electronic or electrical interference. Anything less is likely a wasted effort.
WLOS has a permit to build a 250 watt channel 31 translator just north of Greenville that *might* reach you, but I have no information if it's ever been built. It's not in the TVFool database.
Old 31-Jul-2014, 12:24 AM   #4
tpampane
Woos
Thanks for the quick reply. If WLOS is going to build the new transmitter what would the 250 Watt do to the variables in the report? Our guess was we were not receiving WLOS because the signal strength was weak. The variable that we focused in on the report was the NM(db) was at 13.2. So what would the 250 Watt transmitter do to our NM value? Or if our assumption was incorrect with the NM variable what should we focus on if/when the Watts are increased?
Again Thanks for the help
Old 31-Jul-2014, 1:07 AM   #5
I don't know. Since it isn't in the database, there isn't an available calculation. My guess is about 18-20 dB below W28DB before impairments (trees, buildings, etc). While the CP is for a spot on the the same tower as W28DB, it's spot is 55 or so feet below W28DB's antenna. Perhaps Tower Guy might offer some additional insight, he works with similar facilities for a living.
The calculated noise margin for WLOS' channel 13 is a rough approximation based on data which has some significant potential for deviation. It also doesn't include the generally higher noise floor on VHF nor for any local noise floor increases due to electrically noisy stuff in your immediate vicinity or in your home. Plus, there's a ton of FM signal nearby and FM is more apt to cause interference into the VHF channels and, if present, would need to be dealt with (if possible).
Old 31-Jul-2014, 6:16 PM   #6
To try for WLOS in the attic get a Y10-7-13 plus a channel 13 jointenna from the Channelmaster store. Aim the antenna at 5 degrees and try it without your existing antenna. If it works, then combine the two antenna with the jointenna.
Old 2-Aug-2014, 12:33 AM   #7
tpampane
Atenna 25' above ground
Teleview -
Here is the new report that is 25' above ground , and when I mount the antenna in the attic it will be at least 25 above ground, it might be closer to 30 feet.
http://www.tvfool.com/?option=com_wr...e1c6fe4364dd6d
Tower Guy -
Thanks for the advice. I just purchased the jointenna from channelmaster. I will look to source the y10-7-13 from different vendors. Do any vendors/suppliers have a better y10-7-13 antenna - or are they all the same?
Thanks to all for the help ! I have built ladders in my attic to get these antenna/s so i can cut the cable cord!
Old 5-Aug-2014, 9:39 PM   #8
Here's the data for the construction permit. The NM at your location will be about 15 db.
https://licensing.fcc.gov/cgi-bin/ws...fac_num=190612
Old 6-Aug-2014, 12:04 AM   #9
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building , in the directions of , North , North East , East , South East , South , South West , West.
Install a.
http://www.antennacraft.net.
Y10-7-13 , VHF high band channel 7 thru 13 antenna.
Aim the Y10-7-13 antenna at about 11 degree magnetic compass direction.
Here is how to aim antennas.
About 3 feet above the Y10-7-13 antenna on the same antenna mast.
Install a , Antennas Direct , DB8e , current UHF channels 14 thru 51 antenna.
http://www.amazon.com.
Aim 1 panel at about 31 degree magnetic compass direction.
Aim the other panel at about 129 degree magnetic compass direction.
Install a , http://antennacraft.net.
10G221 preamplifier.
Connect the Y10-7-13 VHF antenna to the VHF connection of the 10G221 preamp.
Connect the DB8e UHF antenna to the UHF connection of the 10G221 preamp.
Buy the , HFS-2D , HFS-3D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Install the , ronard(4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
Also know this.
As always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception.
Absorbing and Blocking Tv Reception.
The Best Practice for Reliable Reception is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own , attic , roof , building.
