Old 17-Jul-2014, 5:19 AM   #1
Camano viewer
Suggestion for antenna
My GPS is:
48.251802N
-122.447142W
alt. 141 ft.
Can locate antenna on roof. Approximately 25-30 ft. above ground.
I would like a suggestion for a multidirectional antenna. If need be amplifier and rotor is okay.
Any help with this will be appreciated.
Camano viewer is offline   Reply With Quote
Old 17-Jul-2014, 6:56 AM   #2
Here is the TVFR for the GPS coordinates provided,
25': http://www.tvfool.com/?option=com_wr...e1c64c06410f5a
30': http://www.tvfool.com/?option=com_wr...e1c688a554105d
Given the distance between the north end of Camano Island and the Seattle transmitters as well as the obstructing terrain, I would opt for a full size combination such as an Antennas Direct DB8E + Antennacraft Y10713 + RCA TVPRAMP1R preamplifier. Start with the DB8E facing about 150° and the Y10713 pointed at about 175° per a compass.
The TVPRAMP1R has inputs for both antennas.
Be sure to avoid aiming into nearby trees or structures, including your own.
